Days Out on Subcontract Operation
FYI...I finally discovered the reason that the Days Out were not pulling correctly into the Job.
The BOM in question had one subcontract operation and there was no Unit Cost filled in, but there was an entry in the Days Out. However, when the Job Details were pulled in there was a Unit Cost, but no Days Out. After further investigation and discussion, I found that there is a Supplier Price List that allows multiple prices and lead times (which become Days Out) that will override the general information in the BOM.
--- In vantage@yahoogroups.com, "chouse1000" <cindy.house@...> wrote:
> Justin,
> That is exactly what I meant, but we have filled in the information on the part method, however, it is not pulling to the job through the job details like it should. Once we get job details, we go to the Job Entry/Operation/Subcontract Operation and the Days Out field is zero. I don't know if this version has a bug, but it does not work for us.
> --- In vantage@yahoogroups.com, "justincalbraze" <justint@> wrote:
> > Make sure the value is entered on the method of the part. Select the subcontract operation, go the subcontract tab, and have a number filled in for days out.
> > Then when those details get pulled into the job it should populate.
> > On the Job Entry window you can see the same information, select the subcontract operation, go to the subcontract tab and you'll see a field for days out.
> > Is this what you meant?
> > Justin
> > --- In vantage@yahoogroups.com, "chouse1000" <cindy.house@> wrote:
> > > We are currently running Vantage 8.03.408B. In our Method Master we have recently added the "Days Out" for the Subcontract Operations. In the help screen on "Engineering Workbench - Operations Subcontract" it says, and I am summarizing, that this is the estimated number of production days the parts will be out, and this will be used when scheduling the job.
> > > Again in the help screen for "Job Entry - Subcontract Detail" is says, and I am summarizing, that this is the estimated number of calendar days that the parts will be out, and that the default Days Out value is pulled from the selected operation, but can be changed.
> > > I am aware that one help screen refers to production days and the other to calendar days, which is not my issue today. Both help screens however, state that the Days Out is pulled from the operation and therefore should be seen on the Job once the Job Detail is brought in. However, our is not pulling the Days Out into the Job at all.
> > > What am I missing? Is anyone else having this problem, and if so, do you have a solution?
> > > Thanks, Cindy
Thanks, Cindy
Justin
> Thanks, Cindy
Justin,
> Justin
> > Thanks, Cindy
