DB Question Blank Title 122033
Jose,
Did you ever get to the bottom of this.  I have this now also....It does look like it being caused by a BAM that I have a .p attached to.
Cheers
Simon Hall
I am seeing this all over my error logs. We are SQL 8x any ideas?
You tried to compare or to update a character field with a value longer
than the maximum length.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
Jose,
It may be a few things. If everything has been going along ok error free then it could be that you have a corrupt index on the SQL box or even a table. Check the SQL error logs for anything unusual. If you don't have any maintenance plans in place to keep track of your SQL DB then this would be a good time to start. You can use the once created with the DB Maintanance Plan Wizard or you can grab some DB admin type scripts from places like DB_Forums. They are a good source of information about SQL.
If you do need to do anything then a good place to start is doing a DBCC checkdb, BUT please make sure you read any details about running the command as you can break things. SQL books online is an excellent resource for this also.
I hope I am not telling you to suck eggs here, but if you can, restoring a copy of the database and playing with that is always a safe option.
If you do have all of these things in place and SQL is not reporting any errors then it may be something as simple as a problem in the DB creation scripts from Epicor and they have a field that is in progress side that has more characters than in the SQL DB. Typically if you were using SSMS with a query and you perform an update or a an insert into a predefined table (permanant of temporary) manually you would get a message stating "Sting or Binary Data will be truncated". It may be that the progress log error is being translated from SQL in that fashion to get the error that you are seeing.
Finally I have never seen this happen in our environment so I can only go on what information and experience dealing with SQL for the time I have been using Epicor products.
I hope that helps.
Cheers
Simon
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
Thanks Simon I'll poke around.
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Sat, Jun 22, 2013 at 6:35 AM, s1mhall <s1mhall@...> wrote:
> Jose,
> for this also.
> seeing.
> I hope that helps.
> Cheers
> Simon
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
