Have you run the Vantage utility to determine if a re-indexing of
the database is required? You can ask support for Page: 5059MPS this
will give you the Index Factors showing if a re-indexing is
required. Hope this helps, they should also be able to give you an
idea of how much time it will required based on size of your
database.
database.
--- In vantage@yahoogroups.com, "Jasper Recto" <jrecto@l...> wrote:
> I was just given the information on how to run the Truncate Bi
utility, the DB repair utility and the Index Rebuild utility.
> Why would I need to run these utilities?
> When SHOULD I run these utilities?
> How long do they normally take? Should I sent a weekend aside to
> Thanks,
> Jasper
