This has been generated without the user disconntecting. This is happening
to one user primarily and I have watched while he has been kicked out of the
system for no obvious reason. To my knowledge he does not simple switch off
his machine without shutting down.
Sent: July 13, 2000 12:55 PM
To: vantage@egroups.com
Subject: Re: [Vantage] dcdv7.lg
This usually happens when a user disconnects without logging out of the
database first. A couple of questions:
- Have any of your users reported being kicked out of the system suddenly,
for no obvious reason?
- are any of your users in the habit of simple switching off their machine,
without first doing a shutdown?
- Is it always the same user who creates this error message? (To determine
this, you will need to back through the log, and see who user 17, in this
case,actually is)
HTH.
Programmers, with their inbuilt sense of order and discipline, should really
be running the world.
William E. Colls Tel 613 591 0079
PROComputer Systems Fax 613 591 3924
67 Willow Glen Dr www.procomsys.com
Kanata Ontario Canada K2M 1T1 PEG Member 1998051404
Specialists in Progress software development since 1985
case,actually is)
HTH.
