I didn’t build the BAQ. But, it uses the ZDataField table in Epicor as a way to count, I think.
The RowCount subquery just uses that table, and this calculated field:
RowNum (int)
ROW_NUMBER() OVER(ORDER BY ZDataField.SysRevID ASC)
This gets joined to the RTU subquery at the top level with the relation:
Calculated_RowNum <= [Ice].num_entries(RTU.ResourceTimeUsed_LoadDays,'~')
I think this is where the magic happens. You want every single value parsed out of the list of values separated by the tilde. But you don’t know how long that list might be. I think the rowcount in the ZDataField table just allows you to count up very high. We have nearly 150k rows in that table.
Honestly I don’t fully understand it either, but I know that it works in this case. Often my query times-out. I just choose a smaller date range for the parameters.
The RTU subquery return a ton of fields from the ResourceTimeUsed table, with a criteria on the table to filter the load date by start and end date parameters. At the top level the RTU and Rowcount are joined, along with the other relevant tables in this fashion:
My final, working BAQ has a few more levels on top of the subquery1, which should work fine as a top level. I added two more layers to filter only the resource groups I care about. You have to be really careful about filtering out enough data to allow the BAQ designer to show it without timing out. Thats why I filter for resource groups and use the date range parameters on the load dates.
Here’s the SQL if you know how to build it from that.
* Disclaimer!!!
* This is not a real query being executed, but a simplified version for general vision.
* Executing it with any other tool may produce a different result.
select
[SubQuery4].[ResourceTimeUsed_WhatIf] as [ResourceTimeUsed_WhatIf],
[SubQuery4].[Resource_ResourceGrpID] as [Resource_ResourceGrpID],
[SubQuery4].[Calculated_LoadMonth] as [Calculated_LoadMonth],
[SubQuery4].[JobHead_JobNum] as [JobHead_JobNum],
[SubQuery4].[JobHead_PartNum] as [JobHead_PartNum],
[SubQuery4].[JobHead_ProdQty] as [JobHead_ProdQty],
[SubQuery4].[JobAsmbl_PartNum] as [JobAsmbl_PartNum],
[SubQuery4].[JobOper_OprSeq] as [JobOper_OprSeq],
[SubQuery4].[JobOper_RunQty] as [JobOper_RunQty],
[SubQuery4].[JobOper_ProdStandard] as [JobOper_ProdStandard],
[SubQuery4].[Calculated_EarnedHours] as [Calculated_EarnedHours],
(sum(cast(SubQuery4.Calculated_LoadHours as decimal (5,2)))) as [Calculated_TotalLoad]
from (select
[SubQuery1].[ResourceTimeUsed_WhatIf] as [ResourceTimeUsed_WhatIf],
[SubQuery1].[Resource_ResourceGrpID] as [Resource_ResourceGrpID],
(datepart(month, SubQuery1.ResourceTimeUsed_LoadDate)) as [Calculated_LoadMonth],
[SubQuery1].[JobHead_JobNum] as [JobHead_JobNum],
[SubQuery1].[JobHead_PartNum] as [JobHead_PartNum],
[SubQuery1].[JobHead_ProdQty] as [JobHead_ProdQty],
[SubQuery1].[JobAsmbl_PartNum] as [JobAsmbl_PartNum],
[SubQuery1].[JobOper_OprSeq] as [JobOper_OprSeq],
[SubQuery1].[JobOper_RunQty] as [JobOper_RunQty],
[SubQuery1].[JobOper_ProdStandard] as [JobOper_ProdStandard],
((SubQuery1.JobOper_RunQty * SubQuery1.JobOper_ProdStandard)/60) as [Calculated_EarnedHours],
(SubQuery1.Calculated_DayLoadHours) as [Calculated_LoadHours]
from (select distinct
[Resource].[ResourceGrpID] as [Resource_ResourceGrpID],
[ResourceGroup].[Description] as [ResourceGroup_Description],
[JobHead].[PartNum] as [JobHead_PartNum],
[JobAsmbl].[PartNum] as [JobAsmbl_PartNum],
([Ice].entry(RowCount.Calculated_RowNum, RTU.ResourceTimeUsed_LoadHours,'~')) as [Calculated_DayLoadHours],
[RowCount].[Calculated_RowNum] as [Calculated_RowNum],
[JobHead].[JobNum] as [JobHead_JobNum],
[RTU].[ResourceTimeUsed_LoadDate] as [ResourceTimeUsed_LoadDate],
[RTU].[ResourceTimeUsed_WhatIf] as [ResourceTimeUsed_WhatIf],
[JobOper].[RunQty] as [JobOper_RunQty],
[JobOper].[ProdStandard] as [JobOper_ProdStandard],
[JobHead].[ProdQty] as [JobHead_ProdQty],
[JobOper].[OprSeq] as [JobOper_OprSeq]
from (select
[ResourceTimeUsed].[Company] as [ResourceTimeUsed_Company],
[ResourceTimeUsed].[JobNum] as [ResourceTimeUsed_JobNum],
[ResourceTimeUsed].[AssemblySeq] as [ResourceTimeUsed_AssemblySeq],
[ResourceTimeUsed].[OprSeq] as [ResourceTimeUsed_OprSeq],
[ResourceTimeUsed].[OpDtlSeq] as [ResourceTimeUsed_OpDtlSeq],
[ResourceTimeUsed].[WhatIf] as [ResourceTimeUsed_WhatIf],
[ResourceTimeUsed].[AllocNum] as [ResourceTimeUsed_AllocNum],
[ResourceTimeUsed].[ResourceGrpID] as [ResourceTimeUsed_ResourceGrpID],
[ResourceTimeUsed].[ResourceID] as [ResourceTimeUsed_ResourceID],
[ResourceTimeUsed].[StartDate] as [ResourceTimeUsed_StartDate],
[ResourceTimeUsed].[StartTime] as [ResourceTimeUsed_StartTime],
[ResourceTimeUsed].[EndDate] as [ResourceTimeUsed_EndDate],
[ResourceTimeUsed].[EndTime] as [ResourceTimeUsed_EndTime],
[ResourceTimeUsed].[Lock] as [ResourceTimeUsed_Lock],
[ResourceTimeUsed].[LoadDate] as [ResourceTimeUsed_LoadDate],
[ResourceTimeUsed].[LoadHour] as [ResourceTimeUsed_LoadHour],
[ResourceTimeUsed].[EstHours] as [ResourceTimeUsed_EstHours],
[ResourceTimeUsed].[ActualHours] as [ResourceTimeUsed_ActualHours],
[ResourceTimeUsed].[LoadDays] as [ResourceTimeUsed_LoadDays],
[ResourceTimeUsed].[LoadHours] as [ResourceTimeUsed_LoadHours],
[ResourceTimeUsed].[RestoreFlag] as [ResourceTimeUsed_RestoreFlag],
[ResourceTimeUsed].[SysDate] as [ResourceTimeUsed_SysDate],
[ResourceTimeUsed].[SysTime] as [ResourceTimeUsed_SysTime],
[ResourceTimeUsed].[JobEngineered] as [ResourceTimeUsed_JobEngineered],
[ResourceTimeUsed].[DailyProdQty] as [ResourceTimeUsed_DailyProdQty],
[ResourceTimeUsed].[SysUser] as [ResourceTimeUsed_SysUser],
[ResourceTimeUsed].[SysRowID] as [ResourceTimeUsed_SysRowID]
from Erp.ResourceTimeUsed as ResourceTimeUsed
where (ResourceTimeUsed.LoadDate >= @StartDate and ResourceTimeUsed.LoadDate <= @EndDate)) as RTU
inner join Erp.Resource as Resource on
Resource.Company = RTU.ResourceTimeUsed_Company
and Resource.ResourceID = RTU.ResourceTimeUsed_ResourceID
inner join Erp.ResourceGroup as ResourceGroup on
Resource.Company = ResourceGroup.Company
and Resource.ResourceGrpID = ResourceGroup.ResourceGrpID
inner join (select
(ROW_NUMBER() OVER(ORDER BY ZDataField.SysRevID ASC)) as [Calculated_RowNum]
from Ice.ZDataField as ZDataField) as RowCount on
RowCount.Calculated_RowNum <= [Ice].num_entries(RTU.ResourceTimeUsed_LoadDays,'~')
inner join Erp.JobOper as JobOper on
JobOper.Company = RTU.ResourceTimeUsed_Company
and JobOper.JobNum = RTU.ResourceTimeUsed_JobNum
and JobOper.AssemblySeq = RTU.ResourceTimeUsed_AssemblySeq
and JobOper.OprSeq = RTU.ResourceTimeUsed_OprSeq
inner join Erp.JobAsmbl as JobAsmbl on
JobAsmbl.Company = JobOper.Company
and JobAsmbl.JobNum = JobOper.JobNum
and JobAsmbl.AssemblySeq = JobOper.AssemblySeq
inner join Erp.JobProd as JobProd on
JobProd.Company = JobAsmbl.Company
and JobProd.JobNum = JobAsmbl.JobNum
inner join Erp.JobHead as JobHead on
JobHead.Company = JobProd.Company
and JobHead.JobNum = JobProd.JobNum
and ( JobHead.JobClosed = false )) as SubQuery1
where (SubQuery1.Resource_ResourceGrpID in ('2B', '4A', 'MCU'))) as SubQuery4
group by [SubQuery4].[ResourceTimeUsed_WhatIf],
[SubQuery4].[Resource_ResourceGrpID],
[SubQuery4].[Calculated_LoadMonth],
[SubQuery4].[JobHead_JobNum],
[SubQuery4].[JobHead_PartNum],
[SubQuery4].[JobHead_ProdQty],
[SubQuery4].[JobAsmbl_PartNum],
[SubQuery4].[JobOper_OprSeq],
[SubQuery4].[JobOper_RunQty],
[SubQuery4].[JobOper_ProdStandard],
order by SubQuery4.ResourceTimeUsed_WhatIf, SubQuery4.JobHead_PartNum, SubQuery4.JobAsmbl_PartNum, SubQuery4.JobOper_OprSeq
Good luck!
