Decimal Place on Pick List
Hi,
Bit of a novice with SSRS so here goes.
The Sales Order pick list report uses the following formula for its quantity
=FormatNumber(Fields!Calc_RelQty.Value, First(Fields!DecimalsQuantity.Value, “RptParameter”))
This only displays to 2 decimal points, how can I make the formula return 3 decimal points.
Try:
=FormatNumber(Fields!Calc_RelQty.Value, 3)
Hi David,
thanks for responding. I tried your suggestion and it only works if you select no filter in the parameters report. The second half of the expression is looking for the parameter.
What do you mean by that?
Not sure I understand. Its only looking for the parameter because the expression is telling it to. By putting a number in there, it should be using that to determine the number of decimal places instead of a “parameter”.
If I replace the expression with the one suggested the parameter part does not work on the report.
You can try this. I use this in my SSRS reports. For the Expression, just use ‘=Fields!Calc_RelQty.Value’. I then update the Number Properties to what I desire via the Text Box Properties for the field.
Thanks guys that has worked.
