Default Printer - Settings (Dashboard)
When a user goes and clicks on the Print icon, it doesn’t prompt them to select which printer when printing from a custom dashboard. Is this defaulted to use the Windows print set up or where is the printer setting set up within Epicor? Is there a way to overwrite the default printer in a custom dashboard?
“When the Print icon is pressed, the “Select Printer” dialog does not appear and it “just” prints.”
