Default Report style 8.03.804
Thanks, That worked.
Â
Dale's message went into the spam file for some reason and I did not see it until I went looking for it.
I need to try now to figure out why some are going into the spam folder.
Â
Thanks Doug
--- On Wed, 2/11/09, Lynn <lynn.khalife@...> wrote:
Subject: [Vantage] Re: Default Report style 8.03.807
Date: Wednesday, February 11, 2009, 9:48 AM
Did you press the Refresh button at the top as Dale suggested
yesterday on this thread?
He was right. That worked for me.
If that doesn't work, try my previous trick of making a change to the
report style then hitting save. This causes the checkbox to appear
for me. Then you can make changes back to the way they were and save
again with the check box checked.
Lynn
--- In vantage@yahoogroups .com, DD <ddavis4569@ ...> wrote:
> There is not a Default box to check on my system.
> I am on 8.03.807.
> On the standard style there is the company info at the bottom.
> On the custom style the company info is blank.
> Any Idea why we can not set the defaults for the company?
> --- On Mon, 2/9/09, Jeff Stockard <jeff.stockard@ ...> wrote:
> From: Jeff Stockard <jeff.stockard@ ...>
> Subject: RE: [Vantage] Default Report style
> To: vantage@yahoogroups .com
> Date: Monday, February 9, 2009, 3:15 PM
> Open the System Management folder. Open the Company Maintenance
folder.
> Click on the Report Style Icon. Select the report you want to set
the
> default on. Click on the Styles tab. Put a check mark in the
Default box
> and save it. Sometimes users have to log out of Vantage and log
back in to
> see changes.
> Jeff
> From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On
Behalf Of
> Bill Wu
> Sent: Monday, February 09, 2009 3:57 PM
> Subject: [Vantage] Default Report style
> Can someone tell me how to set a specific report style as the
default so
> each time when the user prints, she or he does not need to change
it? I'm
> work with ArForm's Print invoice.
> Thanks in advance.
> Bill Wu
Can someone tell me how to set a specific report style as the default so each time when the user prints, she or he does not need to change it? I'm work with ArForm's Print invoice.
Thanks in advance.
Bill Wu
Open the System Management folder. Open the Company Maintenance folder.
Click on the Report Style Icon. Select the report you want to set the
default on. Click on the Styles tab. Put a check mark in the Default box
and save it. Sometimes users have to log out of Vantage and log back in to
see changes.
Jeff
Bill Wu
Thanks in advance.
Bill Wu
Unfortunately there is a flaw in the Report Style maintenance module
in 8.03.404. Unless you actually make a change to the report style,
the Checkbox for Default Style will probably not be visible.
When I need to check or uncheck the default box, I do this: I change
the name of either the Crystal Report file or I choose a different
data definition. Then Save these "bad" changes. Upon saving, now
the default box is displayed. At this time, I change the settings
back to what they are supposed to be, check the Default Report Style
box, and re-save.
Lynn
--- In vantage@yahoogroups.com, "Jeff Stockard" <jeff.stockard@...>
folder.
the
Default box
back in to
> see changes.
> Jeff
Behalf Of
> Bill Wu
default so
it? I'm
> Thanks in advance.
> Bill Wu
Thanks Lynn, you are correct, the check box for the one I want to set is not available. We are using 405A. I will try your trick, today.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Lynn
Sent: Tuesday, February 10, 2009 8:13 AM
box, and re-save.
Lynn
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Jeff Stockard" <jeff.stockard@...>
folder.
the
Default box
back in to
> see changes.
> Jeff
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On
Behalf Of
> Bill Wu
default so
it? I'm
> Thanks in advance.
> Bill Wu
I have found that if you click on the refresh key the default style line
will display.
Dale E. Schuerman
Senior Consultant
RAM Software Systems, Inc.
972-669-0763 x233 (voice)
972-669-9603 (fax)
mailto:dale.schuerman@...
<BLOCKED::blocked::mailto:dale.schuerman@...> (email)
http://www.ramsys.com <BLOCKED::blocked::http://www.ramsys.com/>
(website)
Of Lynn
Sent: Tuesday, February 10, 2009 7:13 AM
box, and re-save.
Lynn
folder.
the
Default box
back in to
> see changes.
> Jeff
Behalf Of
> Bill Wu
default so
it? I'm
> Thanks in advance.
> Bill Wu
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
I am on 8.03.807.
see changes.
Jeff
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Bill Wu
Thanks in advance.
Bill Wu
I did not know that there was an 8.03.807. We are on 8.03.405 and are
waiting for 8.03.408. If you mean 8.00.807, I have never used that
revision. We started on 8.03.305b
DD
Sent: Wednesday, February 11, 2009 10:40 AM
Subject: [Vantage] Default Report style 8.03.807
I am on 8.03.807.
see changes.
Jeff
Of
Bill Wu
Thanks in advance.
Bill Wu
Lynn
> I am on 8.03.807.
> From: Jeff Stockard <jeff.stockard@...>
folder.
the
Default box
back in to
> see changes.
> Jeff
Behalf Of
> Bill Wu
default so
it? I'm
> Thanks in advance.
> Bill Wu
Yes it is a keying error.
Version 8.03.407
Â
--- On Wed, 2/11/09, Jeff Stockard <jeff.stockard@...> wrote:
Subject: RE: [Vantage] Default Report style 8.03.807
DD
I am on 8.03.807.
--- On Mon, 2/9/09, Jeff Stockard <jeff.stockard@ rikerprod. com
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
see changes.
Jeff
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of
Bill Wu
Thanks in advance.
Bill Wu
