Default report style per Company
I have seen that you can set it per company, but I have also seen that
the companies were not available at times and the default checkbox is
not available also...I had to refresh or go out of Vantage and back
in...
Version 8
Of Tony Hughes
Sent: Thursday, November 19, 2009 1:22 PM
Subject: [Vantage] Default report style per Company
In Report Style, can you set Default on a per Company basis?
I do not think so, seems like only one default for everyone, and if
default report not available in the company, user sees a 0 in the drop
down.
That applet is so buggy, I cannot tell if I'm doing it wrong, or it's
just not possible. Thank you.
I do not think so, seems like only one default for everyone, and if default report not available in the company, user sees a 0 in the drop down.
That applet is so buggy, I cannot tell if I'm doing it wrong, or it's just not possible. Thank you.
You can have 5 different companies with 5 different report styles...YES!!!
But I know you are are right it is kind of buggy.
You have to save it on the line after you check Valid and check Default for
that report style; save it and save it again:)
Now if you are a user that has access to all the companies...then 1 company
report style can be the default of course.
Devalidate the Standard. then when you go to your report; your report style
will be the only one in the field; no 0
Tony Hughes
Sent: Thursday, November 19, 2009 2:22 PM
