Default Settings
BPMs: For Op related defaults store them in op master records in ud fields (& the bpm when fired sets those values).
We do not do it with materials but if you have a need, likely can be done.
Sent from Yahoo Mail on Android
To: <vantage@yahoogroups.com>;
Subject: [Vantage] Default Settings
Sent: Wed, Feb 19, 2014 5:30:57 PM
Â
<div id="ygrps-yiv-156343537ygrp-text">
  <p></p><div class="ygrps-yiv-156343537WordSection1"><div><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Good afternoon, all – </span></p><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">  </span></p><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">I would like to have certain fields in Engineering Workbench reset, preferably for our division only. I am being told this cannot be done, so I’m checking with the groupmind. </span></p><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">  </span></p><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">These are the defaults that the user should see:</span></p><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">  </span></p><p class="ygrps-yiv-156343537MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Operations tab, Quantity Factors: Qty should be checked, not %. (radio button)</span></p><p class="ygrps-yiv-156343537MsoNormal"><span
style=“font-size:11.0pt;color:#1F497D;”>
Operations tab, Production per Scheduling Block: Should be Minutes per Piece, not Pieces per Hour. (dropdown menu)
Operations tab, Scheduling Factors: Auto Receive into Inventory and Final Operation should both be checked. (check boxes)
Materials tab, Component: Operations default should be 10 rather than 0. (This is a biggie. Comment: we only ever use one operation in our MoMs.) (dropdown menu)
Â
To recap, I’m trying to change default settings on radio buttons, check boxes and dropdown menus.
Â
I am seeing that in the Operations tab, Labor Reporting Resource, a default pops up, which leads me to believe that defaults are possible in dropdown menus.
Â
If the above is possible, can someone direct me to more information on the “how-to”? What, if any, special skills are required?
Â
As always, many thanks! (Even we non-programmers learn a lot from this list!)
Â
Ree
</div>
<div style="color:#fff;height:0;"></div></div>
I'm having trouble establishing an ODBC connection to a Progress database. The connection worked fine before moving the database to a new server. The test connection responds with the warning message:
[DataDirect][ODBC Progress OpenEdge Wire Protocol driver] (then some strange ascii characters.
If this is a 64 bit system you have to edit the C:\Windows\SysWOW64\odbcad32.exe vice the one in the control panel.
William R. King
IT Analyst
Topura America Fastener, Inc.
1070 Monterey Court - Bowling Green, KY  42101
Voice: 270-901-1579
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of sanfranc415@...
Sent: Tuesday, February 18, 2014 10:27 AM
Subject: [Vantage] ODBC Connection Warning -
I needed to add a line through the Registry Editor –  Under HKEY_LOCAL_MACHINE >  ODBC.INI – (the name I gave to my system DSN).
I needed to add a new string value -  Workaround2 – Data value 8192.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of William King
Sent: Tuesday, February 18, 2014 12:23 PM
Subject: RE: [Vantage] ODBC Connection Warning -
William R. King
IT Analyst
Voice: 270-901-1579
<!-- #ygrps-yiv-1934885877 _filtered #ygrps-yiv-1934885877 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1934885877 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-1934885877 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-1934885877 {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-1934885877 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-1934885877 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-1934885877 #ygrps-yiv-1934885877 p.ygrps-yiv-1934885877MsoNormal, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877MsoNormal, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-1934885877 a:link, #ygrps-yiv-1934885877 span.ygrps-yiv-1934885877MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-1934885877 a:visited, #ygrps-yiv-1934885877 span.ygrps-yiv-1934885877MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-1934885877 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1934885877 code
font-family:“Courier New”;}
#ygrps-yiv-1934885877 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-1934885877 tt
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877MsoAcetate, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877MsoAcetate, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877MsoAcetate
margin:0in;
font-size:8.0pt;
font-family:“Tahoma”, “sans-serif”;}
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877cat
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877ct
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877attach, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877attach, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877bold, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877bold, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877green, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877green, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877replbq, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877replbq, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877ad, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877ad, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877underline, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877underline, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877yshortcuts
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877ad1, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877ad1, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877ad2, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877ad2, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1934885877 p.ygrps-yiv-1934885877underline1, #ygrps-yiv-1934885877 li.ygrps-yiv-1934885877underline1, #ygrps-yiv-1934885877 div.ygrps-yiv-1934885877underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877yshortcuts2
font-weight:normal;}
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877EmailStyle36
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-1934885877 span.ygrps-yiv-1934885877BalloonTextChar
#ygrps-yiv-1934885877 .ygrps-yiv-1934885877MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1934885877 div.ygrps-yiv-1934885877WordSection1
font-family:Symbol;}
#ygrps-yiv-1934885877 ol
{margin-bottom:0in;}
#ygrps-yiv-1934885877 ul
Ree
Update:
Still receiving the error above when connecting using the sqlexp tool locally. I was able to connect to a test database on the same server using the sqlexp tool.
