Default sort when searching
Thanks for the answer
Its not the trouble but since we only search by PO so why have always to click it.
Ephraim Feldman
Sender: vantage@yahoogroups.com
Date: Tue, 31 Aug 2010 16:27:46
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: [Vantage] Re: Default sort when searching
Well, I am afraid if it is too much trouble to click the down arrow and select PO Number in the drop down combo, You will have to either create your own quick search and make it the default or purchase the SDK and re-write the method SetDefaults() in Epicor.Mfg.AD.SalesOrder.Epicor.Mfg.UI.BasicPanel
private void SetDefaults()
for (int i = 0; i < this.cmbSortBy1.Rows.Count; i++)
if (this.cmbSortBy1.Rows[i].Cells[0].Value.ToString() == "OrderNum")
this.cmbSortBy1.Rows[i].Selected = true;
break;
if ((this.whoCalled == "Epicor.Mfg.UI.SalesOrderEntry.dll") || (this.whoCalled == "Epicor.Mfg.UI.SalesOrderTracker.dll"))
for (int j = 0; j < this.cmbOrderType.Rows.Count; j++)
if (this.cmbOrderType.Rows[j].Cells[0].Value.ToString() == "OpenOrder=true")
this.cmbOrderType.Rows[j].Selected = true;
break;
this.radSoldTo.Checked = true;
if (this.txtCustomerName.Text == "")
this.radSoldTo.Enabled = false;
this.radBillTo.Enabled = false;
else if (this.CustID != "")
else
this.radSoldTo.Enabled = true;
this.radBillTo.Enabled = true;
--- In vantage@yahoogroups.com, effgroups@... wrote:
> The default is by order and I want the default to be by PO.
> Ephraim Feldman
> From: "bw2868bond" <bwalker@...>
> Date: Tue, 31 Aug 2010 12:59:15
> Vantage 8.03.405a
> I opened Order Entry from Sales Management - I brought up the search box - the sort by drop down has only 2 options: by order number and by PO number - isn't that what you want?
> --- In vantage@yahoogroups.com, effgroups@ wrote:
> > I wouldn't like to use a baq search I am fine with the regular search.
> > I only want to change the default sort.
> > Ephraim
> > Ephraim Feldman
> > From: advantage@
> > Date: Tue, 31 Aug 2010 11:17:18
> > Subject: Re: [Vantage] Default sort when searching
> > You must create a BaQ default search
> > Sent from my Verizon Wireless BlackBerry
> > From: effgroups@
> > Date: Tue, 31 Aug 2010 11:11:52
> > Subject: [Vantage] Default sort when searching
> > Hi
> > I want to change the default sort in a sort screen. Does anyone know how to do this?
> > For example in the sales order search the default sort is by order number and I want to change it to default it to p/o number how do I do it.
> > Ephraim
> > Ephraim Feldman
Hi
Ephraim
Ephraim Feldman
Hi
Ephraim
Ephraim Feldman
Ephraim
Ephraim Feldman
Hi
Ephraim
Ephraim Feldman
Vantage 8.03.405a
> Ephraim
> Ephraim Feldman
> From: advantage@...
> From: effgroups@...
> Hi
> Ephraim
> Ephraim Feldman
Ephraim Feldman
Vantage 8.03.405a
> Ephraim
> Ephraim Feldman
> From: advantage@...
> From: effgroups@...
> Hi
> Ephraim
> Ephraim Feldman
break;
break;
else
> Ephraim Feldman
> Vantage 8.03.405a
> > Ephraim
> > Ephraim Feldman
> > From: advantage@
> > From: effgroups@
> > Hi
> > Ephraim
> > Ephraim Feldman
