Defining Warning Messages at Order Entry Level
--- In vantage@yahoogroups.com, "Todd Hofert" <todd@...> wrote:
That is all you should have to do. I just did on mine and it worked.
Did you save the customization then exit and go back in to Order
Entry and choose that customization. It has to recompile for it to
work. >
> Vishal,
> This is great! I have the view created and can reference it and I
have
> made a txt box linked to CustomerComments. How do I get it to bring
the
> comments into this field from the customer file?
> Thanks
> Todd (hi-jack?)
Behalf
> Of Michael McWilliams
> Sent: Saturday, September 30, 2006 6:22 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Defining Warning Messages at Order Entry
Level
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Vishal Mehta" <vishy65@> wrote:
> You Can Get it by creating A foreign Key View in Customization.
> When in custom mode go to tools, and then choose data tools.
> You want to create a new custom view.
> Give it a name that is meaningful like CustomerDtl.
> The Parent View would be OrderHed. And then for the column name
> choose CustNumCustID. The rest should stay the same. Click add then
> OK and save your customization. You can now link fields to the
> customer info and create rules or code based on the fields.
> > We have a requirement to prompt a message at order entry level
> based on value of certain field in Customer table. When trying to
> define the trigger thru customization; the customer table is not
> accessible at the order header to define the trigger or rule.
> > I am not a programmer but can manage the basic changes . We are
on
> 8.0. 809
> > any assistance will be appreciated
> > Vishal
> This e-mail and any attachments may contain confidential and
privileged
> information. If you are not the intended recipient, please notify
the
> sender immediately by return e-mail, delete this e-mail and destroy
any
> copies. Any dissemination or use of this information by a person
other
> than the intended recipient is unauthorized and may be illegal.
We have a requirement to prompt a message at order entry level based on value of certain field in Customer table. When trying to define the trigger thru customization; the customer table is not accessible at the order header to define the trigger or rule.
I am not a programmer but can manage the basic changes . We are on 8.0. 809
Vishal
8.0. 809
> Vishal
Vishal,
This is great! I have the view created and can reference it and I have
made a txt box linked to CustomerComments. How do I get it to bring the
Todd (hi-jack?)
Subject: [Vantage] Re: Defining Warning Messages at Order Entry Level
8.0. 809
> Vishal
This e-mail and any attachments may contain confidential and privileged
information. If you are not the intended recipient, please notify the
sender immediately by return e-mail, delete this e-mail and destroy any
copies. Any dissemination or use of this information by a person other
