I added a couple of fields we require via extended UD Table Maintenance in test - I created one of the fields incorrectly as a string rather than an integer. I have synched the current table but not regenerated the data model. When I choose column and click delete I get the message database table xxxx exists do you want to proceed with the delete operation - if I chose yes does this delete just the column or the whole ud table.
We are on 10.0.7.4
