Hopefully this is an easy one. I spent an hour running up and down Epicor to remove a test Dashboard I created. Any quick steps in deleting one?
Dan
Dan
This is pretty straight forward. What did you spend an hour doing?
Go to Dashboard > Load your Dashboard ID > File > Delete Dashboard Definition.
If your dashboard is based on a BAQ, and you want to get rid of that as well: Open Business Activity Query > Load your query ID > File > Delete.
If you have already added the dashboard to a menu, you will want to remove it from the menus as well. Menu Maintenance > Navigate to your menu item > File > Delete.
Good Luck!
Nate
Thanks Nate, Iām on my second day of training with Epicor. Still working on the ropes.
Heh Good luck! This is a great community. Read up and reach out when ever you need help!
Nate
