Delete Order Line
Can you elaborate on what the void looks like?
Patrick Winter
Of Chris Crosta
Sent: Wednesday, October 15, 2008 4:24 PM
Subject: RE: [Vantage] Re: Delete Order Line
Stacey,
In v6.1 closing the line without deleting the demand will produce the
void, may be the same in your version.
Chris
_____
Behalf
Of jsi2001
Sent: Wednesday, October 15, 2008 1:48 PM
Subject: [Vantage] Re: Delete Order Line
Robert,
We are live in Vantage 8.03.403D and there is not a VOID option in
the Action menu for Sales Order line.
Stacey
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
Robert Brown <robertb_versa@...>
wrote:
> Don't delete the record. VOID it via the Actions menu.
> --- On Wed, 10/15/08, jsi2001 <mom2jda@...> wrote:
> From: jsi2001 <mom2jda@...>
> Subject: [Vantage] Delete Order Line
> Date: Wednesday, October 15, 2008, 2:17 PM
> We created a Sales Order and an Advance Billing Invoice was done.
The
> customer has called and said there is one item on the Sales Order
that
> they no longer need. When we try to delete it, we get an error
that
> states: "Delete not allowed. Referenced by at least one invoice".
> Does anyone know if there is a way to override this error and
delete
> the Order Line?
> I did an Advance Billing Credit for that particular line but it
didn't
> do any good.
> Thanks for any help we can get.
> Stacey
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
We created a Sales Order and an Advance Billing Invoice was done. The
customer has called and said there is one item on the Sales Order that
they no longer need. When we try to delete it, we get an error that
Does anyone know if there is a way to override this error and delete
the Order Line?
I did an Advance Billing Credit for that particular line but it didn't
do any good.
Stacey
the Order Line?
do any good.
Stacey
Robert,
Stacey
--- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...>
The
that
that
delete
> the Order Line?
didn't
> do any good.
> Stacey
Stacey,
Chris
_____
Of jsi2001
Robert,
Stacey
The
that
that
delete
> the Order Line?
didn't
> do any good.
> Stacey
Paul Millsaps
Time Manufacturing
254.399.2170
paulm@... <mailto:paulm@...>
This message is for the named person's use only. It may contain
confidential, proprietary or legally privileged information. No
confidentiality or privilege is waived or lost by any mistransmission.
If you receive this message in error, please immediately delete it and
all copies of it from your system, destroy any hard copies of it and
notify the sender. You must not, directly or indirectly, use, disclose,
distribute, print, or copy any part of this message if you are not the
intended recipient.
Of jsi2001
Sent: Wednesday, October 15, 2008 3:48 PM
If you close the line without an invoice against it it automatically
voids the line. I am not sure of the exact process you need to follow
in this case since you have pre-invoiced the line. I would assume you
need to back out the line on the invoice first, then close the line.
Robert,
Stacey
The
that
that
delete
> the Order Line?
didn't
> do any good.
> Stacey
Stacy,
I think Paul is right: It is probably call Close line (or release or order) and it is whether or not activity (including pre-payment) is associated with the line that determines whether OrderDtl.Closed or OrderDtl.Void is set to true.
Likely the Action sets Void to True if no activity & Closed to True of some activity.
(Sorry, remembering interface options on past versions gets confusing as I deal more and more with the data definitions themselves.)
Paul's also right in that no matter what you do, somehow you have to properly disassociate that prepayment from the Order line via a reversal (which I suspect isn't easily possible - if at all - as it likely occurred in a past period) or an adjustment to an offsetting credit to the customer's general A/P account (where it can then be applied to anything else open if you want).
I don't have Vantage available to open from this location right now. I'll check in the AM and reply again if something I said looks fishy.
Rob
Date: Wednesday, October 15, 2008, 6:10 PM
Paul Millsaps
Time Manufacturing
paulm@timemfg. com <mailto:paulm@timemfg. com>
intended recipient.
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of jsi2001
To: vantage@yahoogroups .com
Robert,
Stacey
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ,
Robert Brown <robertb_versa@ ...>
> --- On Wed, 10/15/08, jsi2001 <mom2jda@... > wrote:
> From: jsi2001 <mom2jda@... >
> To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
The
that
that
delete
> the Order Line?
didn't
> do any good.
> Stacey
Thank you all. I did an Advance Billing Credit against that line
and closed the order line. It did void it and everything seems to
be following through nicely.
Thanks again for the help.
Stacey
--- In vantage@yahoogroups.com, "Paul E. Millsaps" <paulm@...> wrote:
> Paul Millsaps
> Time Manufacturing
> 254.399.2170
mistransmission.
and
and
disclose,
the
> intended recipient.
Behalf
> Of jsi2001
automatically
follow
you
line.
> Robert,
> Stacey
> Robert Brown <robertb_versa@>
> > --- On Wed, 10/15/08, jsi2001 <mom2jda@> wrote:
> > From: jsi2001 <mom2jda@>
done.
> The
Order
> that
> that
invoice".
> delete
> > the Order Line?
> didn't
> > do any good.
> > Stacey
