Deleted Company
Good guess :) Was just curious - thanks.
--- In vantage@yahoogroups.com, "Adrian Lauchlan" <adrianlauchlan@...> wrote:
> I'm guessing you are Progress DB? We are on E9 using SQL and the b1 file is
> only 2176 Kb
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> tracy.tmat
> Sent: 22 May 2012 16:07
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Deleted Company
> They're stored in your mfgsys directory and it's the b1 file - we were
> advised it should always be less than 10% of your db file.
> We're on Vantage 8.03.409a if that helps!
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Adrian
> Lauchlan" <adrianlauchlan@> wrote:
> > Hi
> > Keeping a copy of a backup was my 'backup' plan ;-)
> > Where's the bi file kept? I will compare it with another DB
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > tracy.tmat
> > Sent: 22 May 2012 15:42
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > We deleted an old company but have a backup which we keep somewhere
> else...
> > just out of interest did you bi file massively increase when you did it?
> > > Hi Vic
> > > I thought so - I deleted a company we don't use but should have tested
> the
> > > delete first just in case anything goes wrong with one of the other
> > > companies - hopefully not!
> > > Adrian
> > Behalf Of
> > > Vic Drecchio
> > > Sent: 22 May 2012 15:24
> > > Subject: RE: [Vantage] Deleted Company
> > > Roll back to a recent backup? Otherwise, trying to restore to a
> different
> > > environment and surgically restoring portions of the numerous tables
> that
> > > were deleted is an unfathomable task.
> > > Depending on how recently you deleted it and how important it is; you
> > could
> > > halt the system, roll back and reenter transactions.. but that sounds
> like
> > > heartburn, too.
> > > Behalf Of
> > > adrian.lauchlan
> > > Sent: Tuesday, May 22, 2012 10:18 AM
> > > Subject: [Vantage] Deleted Company
> > > Is it possible to restore a company if it has been accidentally deleted?
> > > No virus found in this message.
> > > Checked by AVG - www.avg.com
> > > Version: 2012.0.2176 / Virus Database: 2425/5015 - Release Date:
> 05/22/12
Roll back to a recent backup? Otherwise, trying to restore to a different
environment and surgically restoring portions of the numerous tables that
Depending on how recently you deleted it and how important it is; you could
halt the system, roll back and reenter transactions.. but that sounds like
heartburn, too.
adrian.lauchlan
Version: 2012.0.2176 / Virus Database: 2425/5015 - Release Date: 05/22/12
Hi Vic
I thought so - I deleted a company we don't use but should have tested the
Adrian
Vic Drecchio
heartburn, too.
Behalf Of
adrian.lauchlan
We deleted an old company but have a backup which we keep somewhere else... just out of interest did you bi file massively increase when you did it?
> Hi Vic
> Adrian
> Vic Drecchio
> heartburn, too.
> Behalf Of
> adrian.lauchlan
Hi
tracy.tmat
> Hi Vic
> Adrian
Behalf Of
> Vic Drecchio
could
> heartburn, too.
> Behalf Of
> adrian.lauchlan
I've deleted several companies on our Live database with no issues in 9.x. And if you really need to restore one, Epicor should be able to give you a script that exports/imports every table. But there's probably caveats to the non-company tables if the other companies went forward after the deletion.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, May 22, 2012 7:34 AM
> Hi Vic
> Adrian
> Vic Drecchio
> heartburn, too.
> Behalf Of
> adrian.lauchlan
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
They're stored in your mfgsys directory and it's the b1 file - we were advised it should always be less than 10% of your db file.
> Hi
> tracy.tmat
> > Hi Vic
> > Adrian
> Behalf Of
> > Vic Drecchio
> could
> > heartburn, too.
> > Behalf Of
> > adrian.lauchlan
only 2176 Kb
tracy.tmat
> Hi
Behalf Of
> tracy.tmat
else...
> > Hi Vic
the
> > Adrian
> Behalf Of
> > Vic Drecchio
different
that
> could
like
> > heartburn, too.
> > Behalf Of
> > adrian.lauchlan
05/22/12
