As long as you have done any transactions against the 67, then you need to use an updatable baq or other query to unset the tracklots flag. Then you can adjust the qty out.
If you are using FIFO vs. LOT FIFO as your costing method then the fifo layers are NOT tied to your lots. They are tied to bins.
You can remove more than a lot holds if the bin has enough on hand and the system moves on to the next lot.
Also, if you use lot fifo costing to get strict lot control, then you can’t set standard costs on a part without a lot number.
for us this was a pain since we set the standard as a buying guideline when a part is first entered, but without quantity on hand in a lot we can’t set standard.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Karl Dash
Sent: Thursday, September 20, 2012 7:03 PM
Subject: Re: [Vantage] Deleting after track lots
Tim, on the Qty Adj screen it must tell you what the lot number(s) currently are associated with the 87. Those are the numbers to be entered to down-adjust the inventory. Once inventory is at zero, you can remove the lot tracked flag on the Part Maintenance screen. -Karl
From: sci.thollingsworth <thollingsworth@...<mailto:thollingsworth%40suncountryindustries.com>>
Sent: Thursday, September 20, 2012 1:21 PM
Subject: [Vantage] Deleting after track lots
Hello All,
We have a part number that we received inventory on (qty 87). We then changed the part number to a "track lots" part number. Now I cannot get rid of the 87. I go to do a QTY-ADJ and it will not let me, error code says "must have lot number". The track lots check box is greyed out, so I cannot uncheck requiring lot tracking to remove. Has anyone run into this?
Tim
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Greg
Hello All,
Tim
