Demo Database
Hi All,
Any ideas on why I’m getting this after a refresh demo database? It comes up at login. Running 10.2.700.40
Application Error
Error Detail
Correlation ID: 35315103-7458-4a0a-9f9a-ad765ea6f1f5
Message: Object reference not set to an instance of an object.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
   at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
   at Ice.Proxy.BO.SysConfigImpl.PassSessionValues(String url, String company)
   at Ice.Lib.Startup.PassSessionValues(Session session)
   at Ice.Lib.Startup.PreStart(Session session, Boolean initializeLanguage)
   at IceShell.SessionManager.InitializeInitialSession(Session initialSession)
   at IceShell.SessionManager.<.ctor>b__32_1(Object _, SessionChangedEventArgs e)
   at Ice.Lib.UI.SessionCache.OnInitialSessionChangedEvent(SessionChangedEventArgs e)
   at Ice.Lib.UI.SessionCache.SetInitialSession(Session session)
   at Ice.Lib.UI.SessionCache.set_CurrentSession(Session value)
   at IceShell.SplashScreenApp.logon_LogonEnded(Object sender, EventArgs e)
   at IceShell.Apps.LogonDialog.OnLogonEnded(Object sender, EventArgs e)
   at IceShell.Apps.LogonDialog.StopLogon()
   at IceShell.Apps.LogonDialog.DoWorkLogon()
   at IceShell.Apps.LogonDialog.btnOK_ButtonClick(Object sender, InputEventArgs e)
   at IceShell.ImageButton.Click(InputEventArgs e)
   at IceShell.ImageButton.OnAccessKeyPressed(Object sender, AccessKeyPressedEventArgs e)
   at System.Windows.Input.AccessKeyPressedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
   at System.Windows.Input.AccessKeyManager.GetInfoForElement(IInputElement element, String key)
   at System.Windows.Input.AccessKeyManager.GetTargetsForScope(Object scope, String key, IInputElement sender, AccessKeyInformation senderInfo)
   at System.Windows.Input.AccessKeyManager.GetTargetsForSender(IInputElement sender, String key)
   at System.Windows.Input.AccessKeyManager.ProcessKeyForSender(Object sender, String key, Boolean existsElsewhere, Boolean userInitiated)
   at System.Windows.Input.AccessKeyManager.OnKeyDown(KeyEventArgs e)
   at System.Windows.Input.AccessKeyManager.PostProcessInput(Object sender, ProcessInputEventArgs e)
   at System.Windows.Input.InputManager.RaiseProcessInputEventHandlers(ProcessInputEventHandler postProcessInput, ProcessInputEventArgs processInputEventArgs)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndKeyboardInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawKeyboardActions actions, Int32 scanCode, Boolean isExtendedKey, Boolean isSystemKey, Int32 virtualKey)
   at System.Windows.Interop.HwndKeyboardInputProvider.ProcessKeyAction(MSG& msg, Boolean& handled)
   at System.Windows.Interop.HwndSource.CriticalTranslateAccelerator(MSG& msg, ModifierKeys modifiers)
   at System.Windows.Interop.HwndSource.TranslateAcceleratorCore(MSG& msg, ModifierKeys modifiers)
   at System.Windows.Interop.HwndSource.System.Windows.Interop.IKeyboardInputSink.TranslateAccelerator(MSG& msg, ModifierKeys modifiers)
   at System.Windows.Forms.Integration.ElementHost.ProcessCmdKey(Message& msg, Keys keyData)
   at IceShell.Apps.Controls.WinformsControlHost.ProcessCmdKey(Message& msg, Keys keyData)
   at System.Windows.Forms.Control.PreProcessMessage(Message& msg)
   at System.Windows.Forms.Control.PreProcessControlMessageInternal(Control target, Message& msg)
   at System.Windows.Forms.Application.ThreadContext.PreTranslateMessage(MSG& msg)
Ice.Common.EpicorServerException: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at Epicor.Licensing.CloudLicensingUtilities.UpdateInstanceDetails(String url, String companyId) in C:\_releases\ICE\ICE3.2.700.35\Source\Framework\Epicor.System\Licensing\CloudLicensingUtilities.cs:line 300
   at Ice.Services.BO.SysConfigSvc.PassSessionValues(String url, String company) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Services\BO\SysConfig\SysConfig.cs:line 92
   at Ice.Services.BO.SysConfigSvcFacade.PassSessionValues(String url, String company) in C:\_Releases\ICE\ICE3.2.700.0\Source\Server\Services\BO\SysConfig\SysConfigSvcFacade.cs:line 129
   at SyncInvokePassSessionValues(Object , Object[] , Object[] )
   at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
   at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in C:\_releases\ICE\ICE3.2.700.35\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
   at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:\_releases\ICE\ICE3.2.700.35\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
   --- End of inner exception stack trace ---
Cheers
Yes, done a refresh :smiley:
yeah - read that as ‘Dev’ not demo, thinking you copied Prod to Dev.
Found the problem, license wasnt activated. Easy mistake :joy:
