Save it after importing.
--- In vantage@yahoogroups.com, "dswmaom" <dwalker@...> wrote:
> I have exported the customization in TEST and imported it into
LIVE
> but cannot see the customization available in LIVE when in
developer
> mode. Any ideas what I may have missed? I used the default local
> export/import folder.
> On the import when I select the "use imported customization" the
> customized screen is displayed for that session, but is still not
> available as a choice in developer mode when I exit and reenter
the
> screen.
> If I do not select "use imported customizations" the customized
> screen is not displayed; nor is it available as a choice in
> developer mode.
> I also see a check box for "base only" on the select customization
> screen and do not know what this is for.
> Any tips would be greatly appreciated.
> thx,
> Dale.
> --- In vantage@yahoogroups.com, Kunal Ganguly <kunal_vantage@>
> wrote:
> > Use this at your own risk: export the customization from test
and
> import to live. A much better idea is to re-create the exact same
> customization in the live environment.
> > Thanks,
> > Kunal
> > ----- Original Message ----
> > From: dswmaom <dwalker@>
> > Sent: Monday, July 7, 2008 10:32:21 AM
> > Subject: [Vantage] Deploying Customizations to Other Environments
> > I created and deployed our first customization in "TEST" and it
> appears
> > to be working correctly. How do I deploy this same customization
> > in "LIVE"?
> > thx.
