Deploying Epicor 9 Client Through GPO
Thanks for the response. That is how we deployed Vantage, and is what we are currently doing for E9. I was just excited they are providing an .msi now, and actually hoped to be able to use it.
Thank you,
Craig
--- In vantage@yahoogroups.com, "pbparker" <scrumbus@...> wrote:
> The install is really not all that reliant on being pushed by the msi to be honest. When I rolled out Epicor 9 here, I copied a fresh install from the Program Files directory to all other clients and pushed icons to the all users start menu. (Essentially copied the Epicor904/Client directory).
> There's nothing pushed to the registry so all you need to do is make sure the default.mfgys is configured correctly.
> If you're pushing to Vista or Win7 then it would obviously require tinkering to get it to the right locations and icon paths correct. Just something to consider if you need a way to push out and can't get the msi going.
> --- In vantage@yahoogroups.com, "craig_weiss" <cweiss@> wrote:
> > Has anyone used a GPO to deploy the Epicor 9 client? I can't find any documentation on Epicor's website, and when I try to push the .msi install, it sets the URI path to \\mnsonoma\client, regardless of what is input into the dialog boxes. I assume a .mst is required, but I don't know how to format it. Any help would be appreciated.
> > Thanks,
> > Craig
Craig
Forgot to add that my previous response assumes you've already pushed out the Crystal Reports runtime, etc.
> Thanks,
> Craig
> Thanks,
> Craig
