You can't back-flush serialnum or lot controlled inventory - but you can certainly manually issue it.
--- On Wed, 9/17/08, tpaulavicius <tpaulavicius@...> wrote:
Subject: [Vantage] Re: Diff our and supplier U/M with serial number
Date: Wednesday, September 17, 2008, 7:24 AM
Ok, I'm trying to use lot tracking.
Is it required always enter lot number in part master file?
If I enter lot number only in receipt entry, I can not issue this lot
materials for job.
Tomas
--- In vantage@yahoogroups .com, "CharlieSmith" <CSmith@...> wrote:
> Is your inventory unit of measure on the tin SM and your purchase unit
> of measure RL? When you receive it you would receive it in the supplier
> unit of measure and your unit of measure. You should be using a LOT
> number which would allow you to track the material rather than a serial
> number which would track individual units.
> You can use the lot number in the same way as the serial number and
> would be much easier to use in your business process.
> Charlie Smith
> Smith Business Services / 2W Technologies LLC
> www.vistaconsultant .com <http://www.vistacon sultant.com/> /
> www.2WTech.com
> From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
> Of tomas paulavicius
> Sent: Monday, September 01, 2008 9:01 AM
> To: vantage@yahoogroups .com
> Subject: [Vantage] Diff our and supplier U/M with serial number
> Hello,
> Process:
> 1.Buying tin rolls(must have serial number)
> 2. In system converting rolls to square meters
> Problem:
> Systems converts roll to 10 SM and wants to assign 10 serial numbers,
> thus we would like to assign SN to rol and in serial number tracker see
> that this part is from roll with such SN
> Is that possible?
> Thanks,
> Tom
