Digest Number 3285
Sent: Tuesday, April 26, 2005 12:04 PM
Subject: [Vantage] Digest Number 3285
There are 25 messages in this issue.
Topics in this digest:
1. Soliciting Comments on Job Setup
2. Material Costs for job is greater than costs recorded on GL
3. RE: Material Costs for job is greater than costs recorded on GL
4. RE: Exporting Crystal Reports to Excel on TS
5. RE: Soliciting Comments on Job Setup
6. OT: Registry Cleaner
7. RE: Soliciting Comments on Job Setup
8. Re: Soliciting Comments on Job Setup
9. Re: Soliciting Comments on Job Setup
10. RE: Re: Soliciting Comments on Job Setup
11. RE: Hung or idle Vantage sessions
12. Going Multiplant
13. RE: Hung or idle Vantage sessions
14. RE: Re: Soliciting Comments on Job Setup
15. RE: Re: Soliciting Comments on Job Setup
16. RE: Hung or idle Vantage sessions
17. RE: Re: Soliciting Comments on Job Setup
18. Re: Re: Soliciting Comments on Job Setup
19. RE: Soliciting Comments on Job Setup
20. RE: Re: Soliciting Comments on Job Setup
21. RE: Going Multiplant
22. RE: Re: Soliciting Comments on Job Setup
23. RE: Soliciting Comments on Job Setup
24. RE: Going Multiplant
25. RE: Re: Soliciting Comments on Job Setup
________________________________________________________________________
Message: 1
Date: Tue, 26 Apr 2005 07:51:25 -0400
Subject: Soliciting Comments on Job Setup
We are having a philosophical discussion regarding Job Setups and Bills.
Conditions: 1 or 2 level bills are the norm, 3 to 4 job operations are
the
norm, Version 5.0
Side A:
Says that a part number needs to be created for each job step so that
WIP
amounts processed can be tracked. IE; as part abc1 moves to operation 2
it
becomes part abc2, as it moves to operation 3 it becomes part ABC3 and
so
on. This will necessitate the creation of a part number in the part
master
for each process step, so that materials management will know how much
material is in each step.
Side B:
Says that creating part numbers for each process step is unnecessary
because
Vantage will know through WIP reports how much is in each process step.
Creating additional part numbers will only complicate the process.
Which side is the most appropriate? What is the best way to determine
how
much material is sitting at each process step? What are the
ramifications
of creating part numbers for each process step?
Shirley Graver
Rubber Associates Inc.
Tracking #: B2B6D53CD6228A42B4BB93244CD2DFBCE38E4516
Message: 2
Date: Mon, 25 Apr 2005 21:32:14 -0000
Subject: Material Costs for job is greater than costs recorded on GL
Is there an easy way to find the difference between the Production
Detail Report for a specific job and the Inventory/WIP Account
reconciliation for the same job? Mine is off and Vantage posted the
amount on the Production detail report as a credit when I closed the
job. This posting has created the WIP-Material GL off.
Thanks for any help.
Carol
Electroimpact, INC
carols@...
Message: 3
Date: Tue, 26 Apr 2005 07:36:21 -0500
Subject: RE: Material Costs for job is greater than costs recorded on GL
If you are on version 6.1 you can run an inventory wip reconciliation
report by job, otherwise, you will have to have to run the entire report
for the period of time the job was open & look for the entries that
apply. Most likely the differences will be in a variance account you
designated in your account set-up.
Of pzieve
Sent: Monday, April 25, 2005 4:32 PM
Subject: [Vantage] Material Costs for job is greater than costs recorded
on GL
Carol
Electroimpact, INC
carols@...
Yahoo! Groups Links
Message: 4
Date: Tue, 26 Apr 2005 08:56:53 -0400
Subject: RE: Exporting Crystal Reports to Excel on TS
I have had the same experience. Since I am the only user using this, I
have not tried to track it down. I assumed it was a problem with my
install. Evidently not.
Bruce Butler
IT Manager
Knappe & Koester
bbutler@...
Message: 16
Date: Mon, 25 Apr 2005 17:26:06 -0400
Subject: Exporting Crystal Reports to Excel on TS
I have complied many crystal reports and my users are able to run them
from Vantage and export to Excel without any problems. However, my
Terminal Server users are not able to export to excel. Has anyone run
into this before?
TIA
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
513-831-3211 ext 400
513-831-1209 fax
www.ColdJet.com
Message: 5
Date: Tue, 26 Apr 2005 08:18:16 -0500
Subject: RE: Soliciting Comments on Job Setup
Hi Shirley,
I'm pretty sure Side B is the way to go. the other thing is that each
material on the jobs can be directly assigned to a specific operation.
in
that way you can be sure exactly what is being used and at which point
in
the overall process.
I think side A would drive you all crazy. It's a lot of extra work,
and my
opinion would be that it would all be needless. Vantage does the work
already.
Sent: Tuesday, April 26, 2005 6:51 AM
Subject: [Vantage] Soliciting Comments on Job Setup
the
norm, Version 5.0
Side A:
WIP
it
so
master
Side B:
because
how
ramifications
Shirley Graver
have
and
_____
Yahoo! Groups Links
<http://groups.yahoo.com/group/vantage/>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service
Message: 6
Date: Tue, 26 Apr 2005 10:02:31 -0500
Subject: OT: Registry Cleaner
I'm looking for a registry cleaner for Windows 2000 pro and XP pro.
I downloaded Registry Mechanic trial and did a scan, which found 200
problems on my desktop computer, but was scared to let it repair
anything.
Has anyone found a good reliable registry cleaner? Anyone gotten bitten
by
one?
Best Regards,
Paul Lipham
Information Systems Manager
Alabama Specialty Products, Inc.
256-358-4202
Message: 7
Date: Tue, 26 Apr 2005 10:11:50 -0500
If you were looking to poll people's opinions on this, I
ditto Rhonda.
M. Manasa Reddy
ERP Specialist
Crestview Aerospace Corporation
Email: mreddy@...
Phone: (850) 682-2746 x 272
[mailto:vantage@yahoogroups.com]On Behalf Of Sherer, Rhonda
Sent: Tuesday, April 26, 2005 8:18 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Soliciting Comments on Job Setup
Hi Shirley,
is that each
specific operation. in
which point in
extra work, and my
does the work
already.
Setups and Bills.
operations are the
norm, Version 5.0
Side A:
step so that WIP
to operation 2 it
part ABC3 and so
in the part master
know how much
Side B:
unnecessary because
process step.
process.
to determine how
the ramifications
Shirley Graver
Note: You must have
access. )
Report Builder and
goto:
_____
Yahoo! Groups Links
ibe>
Terms of Service
Note: You must have already linked your email address to a
Report Builder and Crystal Reports and other 'goodies',
please goto: http://groups.yahoo.com/group/vantage/files/.
goto: http://groups.yahoo.com/group/vantage/links
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
Message: 8
Date: Tue, 26 Apr 2005 15:15:59 -0000
Subject: Re: Soliciting Comments on Job Setup
Yes, I am trying to poll other uses. I have a new materials manager
that has limited my input in this area and has decided that after 6
months he knows Vantage better. Management does not seem to be hearing
me.
Shirley
Message: 9
Date: Tue, 26 Apr 2005 15:15:45 -0000
me.
Shirley
Message: 10
Date: Tue, 26 Apr 2005 10:21:21 -0500
Subject: RE: Re: Soliciting Comments on Job Setup
You know, Shirley, you could always give him a test database
to show why his reasoning is just too cumbersome.
Then show how your reasoning makes more sense.
I've done this enough times in the past to show Management
the error of their ways.
Just a thought......
M. Manasa Reddy
ERP Specialist
Email: mreddy@...
[mailto:vantage@yahoogroups.com]On Behalf Of shirleygraver
Sent: Tuesday, April 26, 2005 10:16 AM
Subject: [Vantage] Re: Soliciting Comments on Job Setup
materials manager
that after 6
to be hearing
me.
Shirley
Yahoo! Groups Links
Terms of Service.
Message: 11
Date: Tue, 26 Apr 2005 11:43:18 -0400
Subject: RE: Hung or idle Vantage sessions
Thanks for the responses.
Now, what is the syntax for my database name in Promon?
I've tried UNC and IP:port with no luck.
Are there instructions for this utility somewhere?
I'm stuck at the front door.
Please help.
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
_____
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Thursday, April 21, 2005 10:08 AM
Subject: RE: [Vantage] Hung or idle Vantage sessions
There are 2 different utilities we use depending on the type of hung
session. There's PROMON and also the SYSUSR52.R utility (this is the
name
for 5.2 which we are still on). For the sysusr program, you have to
call
support to get it and it comes with instructions. For promon, you need
to
first set this up on your server, then option 8 to kill a session. I
believe the instructions for setting up promon are part of the Vantage
install guides - if not I know I've found them in the past by searching
the
vantage answerbook. You can also end user sessions directly from
Vantage on
the server only through "System Management" -> "Utilities" -> "Connected
User" -> "Disconnect"...
have
and
_____
Yahoo! Groups Links
Service
Message: 12
Date: Tue, 26 Apr 2005 15:43:11 -0000
Subject: Going Multiplant
Hi Everyone,
We are considering another location in Wisconsin.
What do I want to know about multi plant?
What suggestions do you have?
Who is currently multi plant on version 6.1?
John Mansfield
General Sheet Metal
574 288 0611 x14
Message: 13
Date: Tue, 26 Apr 2005 10:45:07 -0500
These are either in the Vantage instructions when you first
loaded Vantage on your server, or in the mfgbkup.txt file
located in the mfgsys61 directory (towards the bottom).
Just don't remember which one.
I remember it being incredible easy to setup (just pointing
the file to the right path).
HTH,
M. Manasa Reddy
ERP Specialist
Email: mreddy@...
[mailto:vantage@yahoogroups.com]On Behalf Of Conrad, Jeff
Sent: Tuesday, April 26, 2005 10:43 AM
Please help.
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
_____
type of hung
(this is the name
you have to call
promon, you need to
session. I
the Vantage
by searching the
directly from Vantage on
Note: You must have
access. )
Report Builder and
goto:
_____
Yahoo! Groups Links
ibe>
Terms of Service
Yahoo! Groups Links
Terms of Service.
Message: 14
Date: Tue, 26 Apr 2005 08:44:50 -0700
Shirley,
If it would help, I'm sure that our material manager would discuss this
with
him. He has seven years of Vantage.
My comment (with almost 10 years of Vantage experience, two
implementations
of Vantage and 15 years of other software support under my belt) is this
(And I know you all know this already):
The purpose of the job is to show a roadmap of how to create a top
assembly
part. During the manufacturing process, many materials and detail parts
may
have to be bought/manufactured to create that top assembly. As someone
else
said, Vantage keeps complete track of where you are on every job, which
materials and details are required, which have already been issued, how
much
longer it will take to complete and ship. Changing the part number on
every
operation is just going to muddy the water. If you are building a tuna
sandwich (one of my favorite examples), it takes bread, tuna, relish,
mayo,
onion, garlic, tomato and lettuce. If you slice the tomato, it is still
a
tomato, and still a component of the sandwich.
There are exceptions--for example if raw material is sent out for braze
prior to being put on the mill, we bring it in with a different part
number,
since it has been altered. We do this because the material might sit
somewhere in a lot before being issued to a multitude of other jobs. In
the
sandwich example, bread with mayo is still going to be with the original
traveler, waiting for tuna and so on so we don't call it braymo, it just
moves with all the other parts to the assembly area.
Sorry, people who try to make a complex process complicated for their
own
agendas should seriously not be allowed to drive software.
Lydia
Sent: Tuesday, April 26, 2005 8:16 AM
me.
Shirley
have
and
Yahoo! Groups Links
Message: 15
Date: Tue, 26 Apr 2005 08:46:55 -0700
His idea is ludicrous. Management always has a problem hearing a woman
over a man - or at least, that has been "my" experience. You need to
take some time and prepare a statement, in writing. If that does not
work, just forget it and don't sulk. Your time will come and they will
know you advised against it.
Good luck.
Sue
me.
Shirley
_____
Yahoo! Groups Links
Service <http://docs.yahoo.com/info/terms/> .
Message: 16
Date: Tue, 26 Apr 2005 11:46:52 -0400
Did you try searching the epicor eportal answerbook? I know I've gotten
them from there before.
Please help.
Jeff Conrad
IS Analyst
919.956.4303
Firstmark Aerospace
Durham, NC
_____
type of hung
(this is the name
you have to call
promon, you need to
session. I
the Vantage
by searching the
Note: You must have
access. )
Report Builder and
goto:
_____
Yahoo! Groups Links
ibe>
Terms of Service
Yahoo! Groups Links
Terms of Service.
have
and
Yahoo! Groups Links
Message: 17
Date: Tue, 26 Apr 2005 11:44:59 -0400
Actually they don't listen to men either.
Mark
_____
Of
Susan Iverson
Sent: Tuesday, April 26, 2005 11:47 AM
Subject: RE: [Vantage] Re: Soliciting Comments on Job Setup
Good luck.
Sue
me.
Shirley
_____
Yahoo! Groups Links
have
and
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Terms of Service.
Message: 18
Date: Tue, 26 Apr 2005 11:52:28 EDT
Subject: Re: Re: Soliciting Comments on Job Setup
I think you need to show them the side of Mistress Shirley they don't
normally see... Break the wip out... <old joke>
Message: 19
Date: Tue, 26 Apr 2005 08:54:37 -0700
Side B is definitely the way to go.
Unless, the purpose is to complicate the process to such a degree that
no beneficial information can be gleaned, no one will understand
anything, so they will blame Vantage and start looking for a new ERP
system. If that's the desired end result. Then by all means go A!
One thing to consider would be to set up a test database with scenario A
and have them run through a typical part. After they see all the
transactions and parts that they will have to add they should be able to
figure out for themselves that option A is system suicide.
Good Luck!
Mike
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Shirley Graver
Sent: Tuesday, April 26, 2005 4:51 AM
the
norm, Version 5.0
Side A:
WIP
it
so
master
Side B:
because
how
ramifications
Shirley Graver
_____
Yahoo! Groups Links
Message: 20
Date: Tue, 26 Apr 2005 11:55:19 -0400
If I were you I would ask him what specific information he is trying to
get
for each operation and then show him how easy it will be to get it
without
changing part# at each step. To be honest, I wouldn't even know how to
go
about doing that, I don't think Vantage is even set up for that. If you
show him that he can get what he needs without doing that extra work, he
should (hopefully) buy in.
me.
Shirley
Message: 21
Date: Tue, 26 Apr 2005 11:58:25 -0400
Subject: RE: Going Multiplant
We are currently multi-plant and multi company.
Multi-plant works pretty well. Multi company has a few glitches at this
time.
If there is anything you want to know about multi-plant just let me
know.
HTH
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Of mansfield1024
Sent: Tuesday, April 26, 2005 11:43 AM
Subject: [Vantage] Going Multiplant
Hi Everyone,
John Mansfield
General Sheet Metal
574 288 0611 x14
_____
Yahoo! Groups Links
Message: 22
Date: Tue, 26 Apr 2005 08:57:49 -0700
Sarah is correct in that Vantage really isn't set up for this. In
essence you would have a job for each operation.
Would not be fun...
Of sarah.vareschi@...
Sent: Tuesday, April 26, 2005 8:55 AM
get
without
go
me.
Shirley
_____
Yahoo! Groups Links
Message: 23
Date: Tue, 26 Apr 2005 10:59:07 -0500
For purely WIP it would be relatively easy with RB (or Crystal) to watch
the costs at various levels. I guess my first question though on a
part numbering scheme would be whether the sub-assembly parts are ever
put into stock for later final assembly or if they would ever be sold as
repair/replacement parts. If neither of these situations apply then
there would be no need for seperate part numbers at all. The added
complexity would have no benefit.
-Todd C.
the
norm, Version 5.0
Side A:
WIP
it
so
master
Side B:
because
how
ramifications
Shirley Graver
_____
Yahoo! Groups Links
Message: 24
Date: Tue, 26 Apr 2005 09:01:21 -0700
Michelle,
We tried to go Multi-company and found some glitches as well. Would you
care to share off list? We're thinking of moving in this direction
again and I'm curious to see if these are the same or new glitches.
Mike
Of Michelle de la Vega
Sent: Tuesday, April 26, 2005 8:58 AM
Subject: RE: [Vantage] Going Multiplant
time.
know.
HTH
Michelle de la Vega
Cold Jet, LLC
513-831-1209 fax
www.ColdJet.com
Of mansfield1024
Hi Everyone,
John Mansfield
General Sheet Metal
574 288 0611 x14
_____
Yahoo! Groups Links
Service < http://docs.yahoo.com/info/terms/> .
_____
Yahoo! Groups Links
Message: 25
Date: Tue, 26 Apr 2005 11:03:29 -0500
the busy-work would be unimaginable. It makes me ill to think of it. I
can
only see chaos and clogged processes.
I would quit. No one would be pleased. Grouchy people everywhere.
Your production staff can't buy into this can they?
Sent: Tuesday, April 26, 2005 10:58 AM
essence
Would not be fun...
Of
sarah.vareschi@...
get
without
go
me.
Shirley
have
and
_____
Yahoo! Groups Links
Service
<http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
have
and
_____
Yahoo! Groups Links
Service
Yahoo! Groups Links
