I am a new user. Try to understand why WIP report has COS information.
For an example:
Job number xxx
To date 1,000
C O S 400
WIP 600
Bala Lawton
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com]
Sent: Wednesday, February 15, 2006 3:45 PM
To:
Subject: [Vantage] Digest Number 3703
There are 14 messages in this issue.
Topics in this digest:
1. Re: Data Collection Bar Codes (6.1) BAR Code for Receiving?
jfekkes@...>
2. Re: Re: Project Accounting
blue.wine@...>
3. Crystal Help
chris@...>
4. Re: Plant Floor Data Collection (6.1)
bakerprovan@...>
5. Re: Crystal Help
bakerprovan@...>
6. Re: Crystal Help
bakerprovan@...>
7. Vantage/Progress Time - Out
roughbros@...>
8. RE: Vantage/Progress Time - Out
caugheyt@...>
9. RE: Vantage/Progress Time - Out
twojewoda@...>
10. RE: Crystal Help
bbutler@...>
11. RE: Crystal Help
dale.schuerman@...>
12. RE: Crystal Help
aaron.hoyt@...>
13. Not Auto Received
ace_man@...>
14. Re: Not Auto Received
paulkrotts@...>
________________________________________________________________________
Message: 1
Date: Tue, 14 Feb 2006 21:48:44 -0000
jfekkes@...>
Subject: Re: Data Collection Bar Codes (6.1) BAR Code for Receiving?
Along the lines of Bar Coding, has anyone set up to do any other data
entry in Vantage using Bar Codes, i.e. Receiving or Inventory movements?
I thought some were using the AMM module to accomplish this or at least
assist with accomplishing this?
Joy Fekkes
Jaco, Inc
508-553-1040
--- In vantage@yahoogroups.com, "Aaron Hoyt" <aaron.hoyt@...> wrote:
> Rich,
> Ok, here is how to set it up.
> You need to have your barcode scanner enabled for Code39 extended
or full
> ASCII.
> You then need to have a barcode that has these components:
> * = Start and Stop (begin and end all barcodes with this) $M = Enter
> $I = Tab Then appropriate keyboard shortcuts to get the job done.
> For instance. Log in:
> *123$M$M$M$M*
> Start, empid, enter to accept, enter to accept shift, enter to OK
shift
> window, enter to activate Log In/Out, end.
> The same principle can be applied to log into and out of job.
> I modified the traveler to include the following barcode for each
operation.
> IIF ({JOBOPER.BCOPRSEQ} > "" and {@OperVendor} = "", "*" & Trim
> ({JOBOPER.JOBNUM}) & "$M" & Trim ({JOBOPER.ASMSEQ})
& "$M" & Trim
> ({JOBOPER.OPRSEQ}) & "$M" & "$M" & "*"
> This single barcode will scan from the Start Activity screen after
selecting
> Production (or Setup, Rework...).
> It enters the Job Number, enter to get to assm field, then Assm
Seq, then
> enter to move to next field, then Op Seq, then two enters to
accept and ok
> the screen.
> I highly recommend combining barcodes with touch screens. It
makes Data
> Collection quick and painless.
> If this is to detailed, sorry, but I wanted to make sure you had
the tools
> to continue this as desired.
> Good luck,
> Aaron Hoyt
> Vantage Plastics
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On
Behalf
> Of RICH WAGNER
> Sent: Tuesday, February 14, 2006 8:13 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Data Collection Bar Codes (6.1)
> How are you setting up your barcodes? Do you have a single
barcode to
> clock you in or do you have multiple barcodes the employee must
scan?
> How about starting an activity, what is you scanning sequence? I
would
> want our office employees who only clock in and out to start and
end
> their day to be able to just scan a single barcode to clock in and
out.
> I want to keep it simple as possible for starting an activity, but
I
> thinking this will require multiple scans one for the employee
number
> and others for Job Number, Assembly and Operation. I am curious
of how
> other are able to accomplish this.
> I look forward to your response.
> Thanks
> Rich
> _____
> From: Aaron Hoyt [mailto:aaron.hoyt@...]
> Sent: Monday, February 13, 2006 8:32 AM
> Richard,
> Typically when trying to do this, I will tab "$I" to a button and
then
> send
> an "O". Most screens in data collection use O to replace Ok.
> Alternatively
> you can use "$M" enter to accept data in most fields and then
again to
> accept the form in many forms.
> Although not exactly the answer your question, I hope this helps
point
> you
> in a direction.
> Good luck,
> Aaron Hoyt
Behalf
> Of Richard Bailey
> Sent: Monday, February 13, 2006 4:59 AM
> To: UserGroup
> Subject: [Vantage] Data Collection Bar Codes (6.1)
> I'm trying to define some bar codes to replicate key strokes to
make our
> shop users life (even) easier when they use Plant Floor.
> For example I've got one to start direct production activity
defined as
> "*%DA%DP*", i.e. Alt-A, Alt-P, and it works fine. The problem I
have is
> in
> replicating the F2 keystroke (ie OK, Save etc). I'm using "*$B*"
but
> when I
> scan this nothing happens. I'm using a Wasp CCD scanner set to
read Code
> 39
> as Full ASCII with no automatic terminator (CR etc) and the
DataWorks
> Bar39
> symbology.
> Does anyone have any ideas or examples that they are willing to
share?
> Thanks
> Regards,
> Richard
> Richard Bailey
> Dudley Industries
> Mailto: rbailey@...
> Tel: +44(0)1253 738311
> Mob: +44(0)7836 550360
> Fax: +44(0)870 7628173
Message: 2
Date: Tue, 14 Feb 2006 15:59:24 -0800
Subject: Re: Re: Project Accounting
If your projects fit Vantage's definition... it works. Ours doesn't, but
since our problem isn't unique, Epicor would do well to do something
about. I can see it now... ETO module... more $.
Thanks, Scott. We do something similar in Excel.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Tuesday, February 14, 2006 1:03 PM
Subject: [Vantage] Re: Project Accounting
Well,
Wow... I have been looking at your posts from afar. Would it be fair to
say that vantage doesn't really embrace project type work? I understand
that 'projects' was tagged on to the system but it would be great just
to post a misc invoice(ap) to a project. But we are not using projects
to generate wip then cos then invoice etc.
In vantage@yahoogroups.com, "Lepley, Scott A." <sal@...> wrote:
Hello Chris,
I apologize for the long delay in responding, but here's a brief summary
of what we have in place. More work remains, but at least we're moving
in the right direction now. At least I think we are...
I just uploaded a Report Builder report that calculates, for every open
make-to-order job linked to a sales order release flagged as subject to
percentage-of-completion accounting, the actual job costs-to-date, the
percentage-of-completion ratio and the resulting earned revenue-to-date.
In turn, it totals invoiced-to-date and compares that value to the
earned revenue-to-date to determine over- and under-billing. This
report is, without a doubt, the most complicated one that I have ever
created in Report Builder, so suffice it to say that there are probably
better ways to do what I have done in it and that Crystal Reports is
probably much better suited to the task. At some point, I will need to
convert it from RB to CR.
The report is dependent upon the proper use of several user-defined
fields, some of which are set up in VB forms. In sales order releases,
we have a VB form where we designate a planner and whether the release
is subject to PoC. In the corresponding job headers, we use one of the
check-off boxes (JobHead.CheckOff2) to indicate that the job is 'ready
for PoC' and one of the user fields (JobHead.UserInteger1) to enter the
estimated cost from our quote. From there, everything else happens in
the report. Again, there are probably better ways to do this, but this
is the outcome to date of my trials and errors (of which there have been
plenty). Our company president would like to see some cash flow
forecasting added to the report based on anticipated milestone billings,
so I still have that challenge ahead of me. If you have any ideas,
please share.
I hope this helps!
Sent: Tuesday, January 17, 2006 12:41 PM
Subject: Re: [Vantage] Project Accounting
You're the only one, so far. One problem is the percentage complete
revenue recognition, negotiated invoicing and over/under billings
between the two. This we would like Vantage to be more helpful with.
Another is Engineer Purchasing for Engineer To Order, which we can
mostly solve with V8 customization. But Vantage 8.0.805e still corrupts
seven of our large jobs and PO contact phone numbers don't appear on the
screen properly when using a Purchase Point. Purchasing is THE most
important activity for engineers in Vantage and has to work and be
friendly.
We can't go to V8 until its problems are resolved.
Sent: Tuesday, January 17, 2006 9:11 AM
Subject: RE: [Vantage] Project Accounting
Hey Chris, just wanted to let you know that I haven't forgotten about
this, but I just haven't taken the time to summarize our process yet.
Have you received a reply from anyone else?
Sent: Friday, January 06, 2006 5:10 PM
Electroimpact is strictly Engineer To Order (no Inventory) and 15-20
jobs at any one time require percentage-complete accounting which we do
in Excel using Vantage data and then post back to Vantage manually. We
use Miscellaneous Shipments, not Customer Shipments for these jobs, as
we're shipping a unique machine, some assemble jet aircraft wings, in
containers which are reassembled/tested by us at the customer site. Our
estimated job costs are fairly accurate while our actual costs are
accurate as we track all dollars and hours for everyone working on the
job -- engineers, inspectors, machinists and technicians -- with true
pay rates in Vantage. Overtime $ is automatically applied to the jobs
through custom programming. Overhead is allocated based on labor $.
Fiscal period is one year. Being a privately held company, we care more
about IRS forms than GAAP. We're on 6.0 going to 8.0 as soon as it and
we are ready. You would think that Epicor would address our business
better since Vantage 8 and beyond is to support all of their various
Manufacturing Packages. But Project Accounting and ETO Purchasing is
still a pain in Vantage. We can, however, address some of the problems
of ETO Purchasing with the new V8 Customization tools.
Sent: Friday, January 06, 2006 1:10 PM
Holy GAAP, Batman! Based on responses (or lack thereof, really) to
similar postings in the past, I didn't think anyone else was even
interested in doing this strictly in Vantage!
I suspect most Vantage users faced with these issues are using Access,
Excel and/or Crystal Reports (any or all with or without ODBC) to
accomplish their accounting and then posting G/L adjusting entries
accordingly. We have struggled with percentage-of-completion accounting
for long-term contracts for quite a while now. I can try to summarize
what we have done here, but that must wait until next week. In the
meantime, I have for you a few questions based on our experiences here.
By "fiscal period", I presume you mean "one year". Is that right or are
you referring to months or quarters? What criteria do you use to
distinguish contracts subject to percentage-of-completion treatment from
those that are not subject to it, e.g. do you use certain thresholds
related to sales amounts or delivery times? Do you fully plan your jobs
before production begins, so that you have a reasonably accurate
estimated cost in your jobs? If not, can you rely on estimated costs
you're your estimating/quoting process? Is your job cost tracking
reliable? What version of Vantage are you using? Do you use VB forms
and Report Builder?
Sent: Friday, January 06, 2006 3:15 PM
To: Yahoo Vantage
Subject: [Vantage] Project Accounting
How are you handling jobs open through more than one fiscal period where
recognizing revenue on a Cost % Complete basis with Over/Under Billings
are an issue?
Have you heard if Vantage will ever support this type of work directly?
Message: 3
Date: Tue, 14 Feb 2006 16:07:10 -0800
Subject: Crystal Help
Can anyone tell me how to select only the most recent transaction record
for an operation. I have a sub report that lists every operation a job
will go through with a formula field that gives the status of the
operation.
if {LaborDtl.ActiveTrans}=True
Then "In Progress" & "-" & Totext({LaborDtl.ClockInDate}&"
"&{LaborDtl.ClockinTime}&" "&{EmpBasic.Name})
Else if {LaborDtl.ActiveTrans}=False
Then "Work Stopped"& "-" & totext({LaborDtl.ClockInDate}&"
"&{LaborDtl.ClockOutTime}&" "&{EmpBasic.Name})
Else ""
Problem is that when my operators don't complete the operation on the
first clock in I end up with multiple transactions showing up for each
operation and I only need to see the most recent for each operation.
Chris
Message: 4
Date: Wed, 15 Feb 2006 06:10:03 -0000
Subject: Re: Plant Floor Data Collection (6.1)
Ok i have this one for you. What if for a job it is decided to hold
a particular job already to let another job use the same resource.
Because we have this scenario where we have to hold another job as
another job with a higher prior must be started and finished. So my
question is how would you hold another job with its schedule to let
another to start and finish? Because we want to set the other job
with the least priority to wait unit the job with the highest
priority finish with the same resources.
Hope you can help out.
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@...> wrote:
> We have a point system for absenteeism and other infractions
including not clocking in/out properly. They start with 5 points
each year and various things deduct from that. At one point left
they are warned. At zero they are fired. If they have five (or
more) remaining at year end they can roll a point (plus the excess
over five) over for the next year. Gradually accumulating future
leniency. When they get to 10 pts I think there is some sort of
reward. So they learn pretty quickly to clock out before they leave.
> -Todd C.
Behalf Of Richard Bailey
> Sent: Thursday, February 09, 2006 10:56 AM
> To: UserGroup
> Subject: [Vantage] Plant Floor Data Collection (6.1)
> We're looking to start using the Vantage Plant Floor Data
Collection very
> soon. The major concern that management have is that shop workers
will
> 'forget' to End Activity on their current jobs at the end of the
day,
> leading to a lot of work for some admin person(s).
> What advice would you current users offer?
> Any aditional advice on handling varying shift patterns would be
gratefully
> received. Our factory people finish early afternoon on a Friday and
> therefore do not have a lunch break that day. I've not come up
with anything
> more sophisticated than the user having to remember that on Friday
they use
> a different shift than Mon thru Thu
> Regards,
> Richard
> Richard Bailey
> Dudley Industries
> Mailto: rbailey@...
must have already linked your email address to a yahoo id to enable
access. )
Builder and Crystal Reports and other 'goodies', please goto:
> SPONSORED LINKS
> Manufacturing <http://groups.yahoo.com/gads?
t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership
+database+software&w3=Database+mortgage+software&w4=Pda+database+soft
ware&w5=Database+management+software&w6=Database+marketing+software&c
=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership
t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Memb
ership+database+software&w3=Database+mortgage+software&w4=Pda+databas
e+software&w5=Database+management+software&w6=Database+marketing+soft
ware&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database <http://groups.yahoo.com/gads?
t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Member
ship+database+software&w3=Database+mortgage+software&w4=Pda+database+
software&w5=Database+management+software&w6=Database+marketing+softwa
re&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
> Pda <http://groups.yahoo.com/gads?
t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+
database+software&w3=Database+mortgage+software&w4=Pda+database+softw
are&w5=Database+management+software&w6=Database+marketing+software&c=
6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database
t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Memb
ware&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membe
rship+database+software&w3=Database+mortgage+software&w4=Pda+database
+software&w5=Database+management+software&w6=Database+marketing+softw
are&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
> _____
> YAHOO! GROUPS LINKS
> * Visit your group " vantage
<http://groups.yahoo.com/group/vantage> " on the web.
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com <mailto:vantage-
unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
> _____
Message: 5
Date: Wed, 15 Feb 2006 06:13:37 -0000
Subject: Re: Crystal Help
just a thought if you dont get a response from this group go to:
http://groups.yahoo.com/group/crystalreportsusersgroup/ would be the
a specific domain for ur query.
record
a job
> operation.
> Else ""
the
each
operation.
> Thanks,
> Chris
Message: 6
Date: Wed, 15 Feb 2006 06:17:19 -0000
Maybe if you group your detail from Insert/Group... then set your
formula from there. Hope it helps in some way.
record
a job
> operation.
> Else ""
the
each
operation.
> Thanks,
> Chris
Message: 7
Date: Wed, 15 Feb 2006 05:45:18 -0800 (PST)
Subject: Vantage/Progress Time - Out
A while back I remember reading about Progress having the ability to
automatically log a user off Vantage if they have been inactive for a
certain period of time ...
Can anyone have further information on this and know where I can find
whatever I need ....
One question I have is ... can it distinguish between users ... for
example, we have shop floor data collection and wouldn't want those
users logged off.
What are the most popular cars? Find out at Yahoo! Autos
Message: 8
Date: Wed, 15 Feb 2006 08:06:26 -0600
Subject: RE: Vantage/Progress Time - Out
It can't distinguish between users but because the time is continuously
uopdated on DC screens (office or pant version) it will prevent those
from being logged out.
It is pretty much just a matter of a registry setting. I don't recall
off hand the details but there is an AnswerBook item for it on the
ePortal.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Rough Brothers
Sent: Wednesday, February 15, 2006 7:45 AM
To: Vantage Users
Subject: [Vantage] Vantage/Progress Time - Out
users logged off.
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage
software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database
software Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
management software Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
marketing software
_____
YAHOO! GROUPS LINKS
_____
Message: 9
Date: Wed, 15 Feb 2006 09:30:23 -0600
Actually the trick is that once you have data collection on it will
never kick you out, the timeout registry entry will not kick a data
clooection user even if he accessed the window from a Vantage session,
that is how I give my "special" users a little extra ;)
Thomas Wojewoda
Vantage 6.10.529 (or something like that)
Of Todd Caughey
Sent: Wednesday, February 15, 2006 8:06 AM
Subject: RE: [Vantage] Vantage/Progress Time - Out
ePortal.
-Todd C.
Of Rough Brothers
To: Vantage Users
users logged off.
SPONSORED LINKS
Manufacturing
Membership
software
Pda
software Database
marketing software
_____
YAHOO! GROUPS LINKS
_____
Yahoo! Groups Links
This transmission may contain information that is privileged,
confidential and/or exempt from disclosure under applicable law. If you
are not the intended recipient, you are hereby notified that any
disclosure, copying, distribution, or use of the information contained
herein (including any reliance thereon) is STRICTLY PROHIBITED. If you
received this transmission in error, please immediately contact the
sender and destroy the material in its entirety, whether in electronic
or hard copy format. Thank you.
Message: 10
Date: Wed, 15 Feb 2006 13:05:23 -0500
Subject: RE: Crystal Help
Maybe I am underthinking this, but I believe you could set a group based
on the operation, suppress the details, set a condition in your
if-then-else to test for the most recent transaction, and execute.
So basically;
if {LaborDtl.ActiveTrans, maxtrandate} = True then..
Else {LaborDtl.ActiveTrans, maxtrandate} = false then..
Bruce Butler
IT Manager
Knappe & Koester, Inc.
_____
Of Chris Crosta
Sent: Tuesday, February 14, 2006 7:07 PM
Subject: [Vantage] Crystal Help
operation.
Else ""
Chris
SPONSORED LINKS
Manufacturing software
Membership database software
Database mortgage software
Pda database software
Database management software
Database marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
_____
Message: 11
Date: Wed, 15 Feb 2006 12:37:25 -0600
I believe if you group by operation, then Date descending, then Time
descending and suppress detail. Any detail fields that you drag into
the Time group header section will be the last record (descending Sort).
Any detail fields that you drag into the Time group footer section will
be the first record (descending Sort). This is reversed if the time
sort is ascending.
Hope this helps.
Dale E. Schuerman
Senior Consultant
RAM Software Systems, Inc.
Of Bruce Butler
Sent: Wednesday, February 15, 2006 12:05 PM
Subject: RE: [Vantage] Crystal Help
So basically;
Bruce Butler
IT Manager
_____
Of Chris Crosta
operation.
Else ""
Chris
Attention:
This email message is privileged and confidential. If you are not the
intended recipient please delete the message and notify the sender.
Any views or opinions presented are solely those of the author.
This email message has been scanned for Viruses and Content and cleared
by MailMarshal SMTP
For more information go to http://www.ramsys.com
Message: 12
Date: Wed, 15 Feb 2006 13:44:21 -0500
LaborDtl.ClockInMinute contains minutes past base date, so this alone
will
sort date and time.
Good luck,
Aaron Hoyt
Vantage Plastics
Of Dale Schuerman
Sent: Wednesday, February 15, 2006 1:37 PM
sort is ascending.
Hope this helps.
Dale E. Schuerman
Senior Consultant
Of Bruce Butler
So basically;
Bruce Butler
IT Manager
_____
Of Chris Crosta
operation.
Else ""
Chris
Attention:
by MailMarshal SMTP
have
and
Yahoo! Groups Links
Message: 13
Date: Wed, 15 Feb 2006 19:45:20 -0000
Subject: Not Auto Received
Can somebody tell me how I could put together a report on Crystal
Reports 8.5 to tell me if the final operation for a part is "Auto
Receive into Inventory" or not?
Message: 14
Date: Wed, 15 Feb 2006 12:03:35 -0800 (PST)
Subject: Re: Not Auto Received
Hello Ace,
Use the table PartRev and column "AutoRecOpr". Then AutoRecOpr <> 0
for your test. That will tell you all parts that have auto-receipt
turned on.
Hope this helps. If you need more detail I'd be happy to share.
Paul Krotts
JH Baxter & Company
SPONSORED LINKS
Manufacturing software Membership database software Database
mortgage software Pda database software Database management
software Database marketing software
YAHOO! GROUPS LINKS
Visit your group "vantage" on the web.
Yahoo! Groups Links
This Email has been scanned for all potential viruses.
Living Color Enterprises, Inc
