Digest Number 996
Hold down the shift key when you logoff of the default user.
Sent: Thursday, October 26, 2000 10:07 AM
To: vantage@egroups.com
Subject: Re: [Vantage] Digest Number 996
Thanks, Jeff, that worked beautifully. Next question: What if *I* need to
log on? I set it up to automatically log in the default data collection
user. I was kind of expecting that if I manually logged off (to log in as a
different user) that it would let me log in manually. When I log the
default user off, it logs right back in! This default user doesn't have any
administrative authority...
Thanks, Aaron, for the TweakUI suggestion.
Gary Grenier
Bell Manufacturing Co.
ggrenier@...
> From: "Jaske, Jeff" <jjaske@...>
> Subject: RE: RE: dummy terminal question
> You have to edit the registry.
> Good Luck,
> Jeff Jaske
Gary Grenier
ggrenier@...
> Good Luck,
> Jeff Jaske
