Disable C# Code When Customiztion Is Opened Read Only
There is a myForm.IsReadOnly (or something similar) property on the form, check for that before excecuting your code.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
     Â
On Fri, Jun 20, 2014 at 11:18 AM, tsmassey@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span></span></p><p>We have some customizations that have code called by clicking on a button.  We need to deploy the customization in read only mode for some users and would like to do that through creating a menu ID with the read only parameter.  However, the code behind the button can still be executed in a module deployed with the read only option.  </p>
How can we use the read only variable from the software environment to disable the button in the customization code so that we can avoid having a second customization?
</div>
<div style="color:#fff;min-height:0;"></div>
