Disable Dashboard Auto-launch When Launch E10
We have a dashboard that auto-launches every time launch Epicor. Where should I look to disable that, and what parameter specifically regulates that?
It depends what UI you are using Classic vs Modern. It will be under Preferences. In Classic those would load as a tab and in the modern they load standalone.
Perfect … thank you!!
