I would like to disable/hide the ‘Mass Shipment’ option from the Actions menu from the Customer Shipment Entry screen. I have read that you can do this with a BPM, but I am having trouble figuring out how to do this. This is what I see with the trace log when I click on ‘Mass Shipment’…
Ice.Proxy.BO.NamedSearchImpl
GetRows
net.tcp://gray-epicortest/epitestemw/
Ice.Tablesets.NamedSearchTableset
5/5/2021 07:34:21:1247453 AM
1
0
Do you still want the “Mass Shipment” button to work?
If so, the the BPM would need to know if tit was initiated from the Actions menu, or the button click.
A UI customization (using code) would work. Add the following to a form load function (you might need to use the wizard to create the Form Load() function)
Thank you @Mark_Wonsil. I was able to apply the security at the Method and the application shows an Access Denied message when trying to create a ‘Mass Shipment’.
