I believe the only way to disable this button is through the SDK
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Thursday, April 29, 2010 1:07 PM
Subject: Re: [Vantage] Disable or Remove AddNew and Delete
The problem is that I want to control how and where the Add New and Delete gets triggered. Blocking it at the BO or customization level could be tricky because I need to know how it was triggered. It would be far simplier to disable the built in menu and force the user to press a UD button where I have full control over what happens.
From: "robertb_versa@... <mailto:robertb_versa%40yahoo.com> " <robertb_versa@... <mailto:robertb_versa%40yahoo.com> >
Sent: Thu, April 29, 2010 12:14:57 PM
Perhaps thru user security you can limit execution of the core bo method to a select few (as in only you).
If not, perhaps a BPM preprocess trap to prevent execution. (You could likely VB customize the client app(s) involved also - but that may not be as reliable.)
Rob
--- Original Message ---
Sent:Thu 4/29/10 9:50 am
To:vantage@yahoogroups .com
Subj:[Vantage] Disable or Remove AddNew and Delete
Vantage 8.03.408A Progress
With the help of others in this group, I have been able to change the name of the "Add New Parent" and "Add New Child" on the drop down of a UD form. I can even disable these sub menu items, but is there a way I can totaly disable or remove the AddNew and Delete buttons/menu?
Rob
