Disable print button
Something that I just remembered the other thing you can do is trap the beforetoolactivate event. This way every time the user attempts to use the tool you can either cancel it or disable it.
Here is some c# code, cut and pasted so may have missed copying enough of it. This was designed to keep them from deleting something.
//this goes in the initialize section.
baseToolbarsManager.BeforeToolActivate += new Infragistics.Win.UltraWinToolbars.CancelableToolEventHandler(baseToolbarsManager_BeforeToolActivate);
private static void baseToolbarsManager_BeforeToolActivate(object sender, Infragistics.Win.UltraWinToolbars.CancelableToolEventArgs args)
if(oTrans.LastView != oTrans.EpiDataViews["UD100A"] && args.Tool.Key == "DeleteTool")
baseToolbarsManager.Tools["DeleteTool"].SharedProps.Enabled = false;
args.Cancel = true;
else
baseToolbarsManager.Tools["DeleteTool"].SharedProps.Enabled = true;
Jim Kinneman
Encompass Solutions, Inc
--- In vantage@yahoogroups.com, "Stoner, Ken" <kstoner@...> wrote:
> Thanks for the heads up, I noticed that early on, I have it working now, with the exception of finding the right events..... which is like finding a needle in a haystack.
> Ken Stoner
> IT Manager
> GP Innovative Machining & Assembly
> office: +1.270.725.7634
> mobile: +1.270.799.1151
> e-mail: kstoner@...
> website: www.general-products.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of jckinneman
> Sent: Wednesday, February 08, 2012 2:48 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Disable print button...
> The other replies give a more complete approach but just for FYI the reason for your error is the use of brackets[], VB likes parenthesis ()
> baseToolbarsManager.Tools("PrintTool").SharedProps.enabled = false would disable the print tool button.
> One other thing to note that just disabling it when you do a form load may not keep it disabled. Depending on the form it will disable and enable the print tool as it sees fit such as when it load a record. You may need to disable it in other places or via events to ensure it stays disabled.
> Jim Kinneman
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Stoner, Ken" <kstoner@> wrote:
> > Hello,
> > Anyone know how to disable a toolbar button using VB?
> > I have found some references to: baseToolbarsManager.Tools["PrintTool"].SharedProps.enabled = false
> > Which I tried putting on the form load event (this is in the customer shipment screen).
> > I get a compile error: Error: BC30545 - line 333 (1227) - Property access must assign to the property or use its value.
> > Error: BC30203 - line 333 (1227) - Identifier expected.
> > Thanks!
> > Ken
> > ________________________________
> > "This e-mail and the files transmitted with it are the property of General Products, are confidential, and are intended solely for use of the individual or entity to whom this e-mail is addressed. If you (a) are not one of the named recipient(s) or otherwise have reason to believe that you have received this message in error, or (b) are unwilling or unable to maintain the confidentiality of this email and the files transmitted with it, please notify the sender and delete this message immediately from your computer. Any other use, retention, dissemination, forwarding, printing, or copying of this e-mail is strictly prohibited."
Hello,
Thanks!
Ken
This is how we remove the Delete
Dim ToolMgr As UltraToolbarsManager = GetType(Epicor.Mfg.UI.App.PartEntry.PartForm).InvokeMember("baseToolbarsManager", BindingFlags.GetField Or BindingFlags.NonPublic Or BindingFlags.Instance, Nothing, PartForm, Nothing)
If (ToolMgr.Tools.Exists("DeleteTool"))
If (ToolMgr.Toolbars.Exists("Standard Tools"))
ToolMgr.Toolbars("Standard Tools").Tools("DeleteTool").InstanceProps.Visible = Infragistics.Win.DefaultableBoolean.False
End If
David Penn
Software Developer
Tel: (260) 918-1559
Fax: (260) 482-4165
www.pyromation.com
E-mail: dpenn@...<mailto:dpenn@...>
[Description: Pyro_4c_Logo-Tag-1.8-email]
5211 Industrial Road, Fort Wayne, IN 46825 USA
Use the top bit or code to find the name of the button (get the sub by going through the wizard then add the messagebox line). After you find the name replace RefreshTool with the name in the messagebox.
   Private Sub baseToolbarsManager_ToolClick(ByVal sender As Object, ByVal args As Infragistics.Win.UltraWinToolbars.ToolClickEventArgs)
      MessageBox.Show(args.Tool.Key.ToString())
   End Sub
   Private Sub JobEntryForm_Load(ByVal sender As Object, ByVal args As EventArgs)
      ' Add Event Handler Code
      baseToolbarsManager.Tools("RefreshTool").SharedProps.Enabled = false
   End Sub
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, February 8, 2012 9:37 AM
Subject: [Vantage] Disable print button...
Hello,
I get a compile error:Â Â Error: BC30545 - line 333 (1227) - Property access must assign to the property or use its value.
Thanks!
Ken
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
Jim Kinneman
> Hello,
> Thanks!
> Ken
That's the problem,
When I add "baseToolbarsManager.Tools["PrintTool"].SharedProps.enabled = false" to the formload event
"PrintTool" is the correct button.
I get:
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Ted Koch
Sent: Wednesday, February 08, 2012 9:16 AM
Subject: Re: [Vantage] Disable print button...
End Sub
End Sub
From: "Stoner, Ken" <kstoner@...<mailto:kstoner%40general-products.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Hello,
Thanks!
Ken
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
This is close....
Dim ToolMgr As UltraToolbarsManager = GetType(Epicor.Mfg.UI.App.CustShipEntry.CustShipForm).InvokeMember("baseToolbarsManager", BindingFlags.GetField Or BindingFlags.NonPublic Or BindingFlags.Instance, Nothing, CustShipForm, Nothing)
End If
However I'm getting: Error: BC30002 - line 341 (1238) - Type 'UltraToolbarsManager' is not defined.
Ken Stoner
IT Manager
e-mail: kstoner@...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of David Penn
Sent: Wednesday, February 08, 2012 8:59 AM
End If
David Penn
Software Developer
Tel: (260) 918-1559
Fax: (260) 482-4165
www.pyromation.com
E-mail: dpenn@...<mailto:dpenn%40pyromation.com><mailto:dpenn@...<mailto:dpenn%40pyromation.com>>
Ken,
If you want to remove the print icon from the menu this is c# code that I tested this morning. You may need to add reference to the Infragistics dll.
if (ToolMgr.Tools.Exists("PrintTool"))
if (ToolMgr.Toolbars.Exists("Standard Tools"))
ToolMgr.Toolbars["Standard Tools"].Tools["PrintTool"].InstanceProps.Visible =Infragistics.Win.DefaultableBoolean.False;
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Stoner, Ken
Sent: Wednesday, February 08, 2012 4:29 PM
Subject: RE: [Vantage] Disable print button...
That's the problem,
I get:
Ken
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Ted Koch
End Sub
End Sub
From: "Stoner, Ken" <kstoner@...<mailto:kstoner%40general-products.com><mailto:kstoner%40general-products.com>>
To: "vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>>
Hello,
Thanks!
Ken
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><http://groups.yahoo.com/group/vantage/files/>
Ken Stoner
IT Manager
e-mail: kstoner@...
Jim Kinneman
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Stoner, Ken" <kstoner@...> wrote:
> Hello,
> Thanks!
> Ken
