Hi everyone,
I need to be able to disable the Release All tickbox on the order job wizard. The problem is that it only becomes enabled after the Schedule All tickbox is ticked, so simply setting enabled to false on the form customisation did not work. Anyone have any idea how to do this please?
Best regards
Adrian.
RMI
(Renee Israel)
November 6, 2017, 5:03pm
#2
Maybe try a BPM that when the Schedule All is checked, the BPM will then uncheck the Release All box and uncheck the Schedule All box?
You can use custom code to accomplish this. Something like below could be used. This code could use some optimization, if you do it this way.
// Custom code for OrderJobWizForm
// Created: 11/6/2017 11:06:29 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
public class Script
Ice.Lib.Framework.EpiUltraGrid ug;
EpiUltraGrid ug = (Ice.Lib.Framework.EpiUltraGrid)csm.GetNativeControlReference("c73444a5-dfea-48bf-a553-2c2fcd01474c");
ug.AfterCellActivate += new System.EventHandler(ug_AfterCellActivate);
private void ug_AfterCellActivate(object sender, System.EventArgs args)
ug.ActiveRow.Cells["ReleaseChkBox"].Column.CellActivation = Infragistics.Win.UltraWinGrid.Activation.Disabled;
// Begin Custom Code Disposal
// End Custom Code Disposal
Something like this would handle the global Release All and the grid level Release All
using System;
using System.Data;
using Erp.Adapters;
using Erp.UI;
using Ice.Lib;
using Ice.Adapters;
public class Script
Ice.Lib.Framework.EpiCheckBox chkScheduleAll;
Ice.Lib.Framework.EpiCheckBox chkRelease;
chkScheduleAll.Click += new System.EventHandler(chkScheduleAll_Click);
private void chkScheduleAll_Click(object sender, System.EventArgs args)
EpiCheckBox chkRelease = (Ice.Lib.Framework.EpiCheckBox)csm.GetNativeControlReference("a8808397-570b-48e8-bb7b-6225d9270dfe");
chkRelease.Enabled = false;
Thankyou Dan, that looks like the kind of thing I need. I will have a go at
implementing it this week. Thanks again.
Regards
Adrian.
