Disable Report Style
Is there a way to disable a Report Style without deleting it?
If not, is there a way to move a style to the bottom of the drop-down list when printing?
  • I tried adding “zz” to the front of the report style name but they still show up in the same order.
I know that Valid checkbox works in a multi-company setting. It might only work there :man_shrugging:t2:
Unchecking the Valid box works for me. It is the only Style for that report?
The only way I found is by using an updatable BAQ on ice.ReportStyle table to uncheck this value.
@tse.dba No, there are 10 different styles, that’s why I’m trying to shorten the list. Are you multi-company? John Kane pointed out that it may be a multi-company only feature.
Do you have that updateable BAQ linked to a 2nd table besides Ice.ReportStyle? I’m just browsing that table in SSMS now and there is not a column for VALID so I assume it resides in a 2nd table somewhere.
You have to write “HIDE” in the field “CompanyList”
Edit : Hide info on image
I am multicompany
That works perfectly, thank you.
Here is the original thread where I took this tip from :
https://www.epiusers.help/t/unable-to-make-report-style-invalid/47681/10
