I’m trying to disable the mouse wheel event when the focus is within a combo box in an UltraGrid.
I can disable the scrolling for the entire grid, which is not what I want, but I cannot figure out how to do it for that specific combo. I can get the column, but UltraGridColumn does not have an event for OnMouseWheel where I can absorb the handler. Any ideas?
If you change the Combo Box Style to something else could that stop the scrolling? I know there are a few styles where you can disable AutoComplete and Typing forcing the user to click the drop-down.
I got it after all. I spend hours on something to no avail, but then the moment I ask, I find a solution.
// Custom code for MainController
// Created: 1/23/2018 8:31:31 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Ice.BO;
using Ice.UI;
using Ice.Lib;
using Ice.Adapters;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
using Infragistics.Win;
public class Script
EpiUltraGrid grid1;
EpiUltraGrid grid2;
this.grid1 = (EpiUltraGrid)csm.GetNativeControlReference("e4989f9a-c2a5-4ff4-bd19-47e68fd02fa9");
this.grid2 = (EpiUltraGrid)csm.GetNativeControlReference("dc3ed6d0-5423-47d3-98ed-67655d36ae72");
this.grid1.ControlAdded += new System.Windows.Forms.ControlEventHandler(this.grid1_ControlAdded);
this.grid1.ControlRemoved += new System.Windows.Forms.ControlEventHandler(this.grid1_ControlRemoved);
this.grid1 = null;
this.grid2 = null;
this.grid1.ControlAdded -= new System.Windows.Forms.ControlEventHandler(this.grid1_ControlAdded);
this.grid1.ControlRemoved -= new System.Windows.Forms.ControlEventHandler(this.grid1_ControlRemoved);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void MainController_Load(object sender, EventArgs args)
// Add Event Handler Code
grid1.DisplayLayout.Bands[0].Columns["Calculated_Hyperlink"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.URL;
grid2.DisplayLayout.Bands[0].Columns["Calculated_Hyperlink"].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.URL;
UltraGridColumn supplierCol = grid1.DisplayLayout.Bands[0].Columns["OrderDtl_FS_SupplierName_c"];
private void grid1_ControlAdded(object sender, ControlEventArgs e)
EmbeddableTextBox textBox = e.Control as EmbeddableTextBox;
if (textBox != null)
textBox.MouseWheel += new MouseEventHandler(textBox_MouseWheel);
private void grid1_ControlRemoved(object sender, ControlEventArgs e)
textBox.MouseWheel -= new MouseEventHandler(textBox_MouseWheel);
void textBox_MouseWheel(object sender, MouseEventArgs e)
HandledMouseEventArgs args = e as HandledMouseEventArgs;
if (args != null)
args.Handled = true;
Thank you i made it for Erp.UI.Controls.Combos:
EpiCombo cboBuyer;
this.baseToolbarsManager.ToolClick += new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClick);
session= (Session)this.oTrans.Session;
// End Wizard Added Custom Method Calls cmbBuyer
grdList=((EpiUltraGrid)csm.GetNativeControlReference("4d59326f-7a76-4c5c-8e2c-54e630db64da"));
grdSubcontract = ((EpiUltraGrid)csm.GetNativeControlReference("fcef0a0c-90f6-48b5-8133-f892a2515b84"));
cboBuyer = ((EpiCombo)csm.GetNativeControlReference("b734a402-4630-4190-b273-f51cd5f95b37"));
grdSubcontract.DisplayLayout.Bands[0].Columns["BuyerID"].ValueList =cboBuyer;
EpiDataView edvCallContextBpmData = ((EpiDataView)(this.oTrans.EpiDataViews["CallContextBpmData"]));
System.Data.DataRow edvCallContextBpmDataRow = edvCallContextBpmData.CurrentDataRow;
if ((edvCallContextBpmDataRow != null))
try{
edvCallContextBpmDataRow.BeginEdit();
edvCallContextBpmDataRow["CheckBox06"] =false;
edvCallContextBpmDataRow.EndEdit();
catch{}
cboBuyer.MouseWheel += new MouseEventHandler(cboBuyer_MouseWheel);
this.baseToolbarsManager.ToolClick -= new Infragistics.Win.UltraWinToolbars.ToolClickEventHandler(this.baseToolbarsManager_ToolClick);
cboBuyer.MouseWheel -= new MouseEventHandler(cboBuyer_MouseWheel);
void cboBuyer_MouseWheel(object sender, MouseEventArgs e)
if (args != null)
But for Ice.Lib.Framework.EpiUltraCombo it’s easier:
Just change the DropDownStyle
//khởi tạo các biến cục bộ
tblSubModule = new DataTable();
session=this.oTrans.Session as Ice.Core.Session;
epiCheckBoxC_Overwrite.Text = "Overwrite";
epiButtonC_Sync.ReadOnly = true;//khóa nút đồng bộ
this.baseToolbarsManager.Tools["RefreshTool"].SharedProps.Enabled = false;//khóa nút Refresh
this.epiUltraComboC_Module.DropDownStyle = UltraComboStyle.DropDownList;//không cho nhập text
this.epiUltraComboC_Module.Rows[0].Selected = true;
this.epiComboC_Company.DropDownStyle = UltraComboStyle.DropDownList;//không cho nhập text
SearchOnCompanyAdapterFillDropDown();
this.epiComboC_Company.Value = session.CompanyID;
//this.epiComboC_Company.Value = session.CompanyID;
this.epiComboC_Company.ReadOnly = true;//khóa không cho chọn công ty
//epiTextBoxC_Object2.ReadOnly = true;
//epiTextBoxC_Object2.Clear();
epiUltraComboC_TranType.ReadOnly = true;
this.epiUltraComboC_TranType.Rows[0].Selected = true;
this.epiUltraComboC_TranType.DropDownStyle = UltraComboStyle.DropDownList;//không cho nhập text
Thank you so much have a nice day!
