Disabling MES auto populate at the operation
The backspace seems to be working fine.
--SF
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> Yes, your correct, and now the error has gone away. But, now it
> autocompletes and highlights the first autocomplete. Maybe I could
> add a backspace to my barcode to start from scratch?
> --SF
> --- In vantage@yahoogroups.com, "Michael McWilliams"
> <mmcwilliams22@> wrote:
> > Under the Module script put this in:
> > Dim cmbJobOpr As EpiCombo
> > Then after the end sub for Destroy custom code add this:
> > Private Sub StartProdForm_Load(ByVal sender As object, ByVal
> > args As EventArgs) Handles StartProdForm.Load
> > cmbJobOpr = Ctype(csm.GetNativeControlReference("4469529c-d636-
4205-
> > b17a-def6a7469d8f"),EpiCombo)
> > cmbJobOpr.AutoEdit = False
> > End Sub
> > --- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@>
> > wrote:
> > > How can I disable MES from auto populating the operation
number?
> > For
> > > example, a user enters job # 24810-1-1 tabs to assembly select
0
> > tabs
> > > to operation types 1, and this is where it assumes you want 10
> or,
> > if
> > > you enter 10, it assumes you want operation 100, how do I stop
> > this?
> > > Thanks,
> > > --SF
How can I disable MES from auto populating the operation number? For
example, a user enters job # 24810-1-1 tabs to assembly select 0 tabs
to operation types 1, and this is where it assumes you want 10 or, if
you enter 10, it assumes you want operation 100, how do I stop this?
--SF
cmbJobOpr = Ctype(csm.GetNativeControlReference("4469529c-d636-4205-
End Sub
For
tabs
if
this?
> Thanks,
> --SF
Thanks for the response, but I'm getting this error message:
----------errors------------
Error: BC30506 - line 61 (117) - Handles clause requires a
WithEvents variable defined in the containing type or one of its base
types.
** Compile Failed. **
> End Sub
> For
> tabs
or,
> if
> this?
> > Thanks,
> > --SF
The two items below should be one line each not two lines... I am
guessing you pasted it in?
base
> types.
4205-
> > End Sub
number?
> > For
0
> > tabs
> or,
> > if
> > this?
> > > Thanks,
> > > --SF
I made sure that there are only two lines total. I'm stilling
getting that error message.
--SF
> base
> > types.
> 4205-
> > > End Sub
> number?
> > > For
select
> 0
> > > tabs
10
> > or,
> > > if
stop
> > > this?
> > > > Thanks,
> > > > --SF
Sorry I made the assumption you were talking about the Start
Production Activity form. What form are you using?
> Thanks,
> --SF
am
4205-
its
> > base
> > > types.
object, ByVal
d636-
> > 4205-
> > > > End Sub
> > number?
> > > > For
> select
> > 0
> > > > tabs
want
> 10
> > > or,
> > > > if
> stop
> > > > this?
> > > > > Thanks,
> > > > > --SF
--SF
> End Sub
> For
> tabs
or,
> if
> this?
> > Thanks,
> > --SF
