Disappearing PartMtl/BOM Entries
If it makes you feel any better, I submitted it as an enhancement
request almost 1 yr ago, and it is now slated as an enhancement for
9.1.
Thanks for the BPM suggestion.
Craig
--- In vantage@yahoogroups.com, "Mark Wonsil" <mark_wonsil@...> wrote:
> > Just an FYI... We had similar complaints about materials dropping
off
> > the BOM of jobs, and I learned the hard way that if a material is
> > deleted, it's records in the change log go with it. So don't go
> > looking in the change log to determine how a material got
deleted. I
> > haven't checked the chglog table to see if the records are still
> > there, but you definitely can't look at them in the GUI.
> Wow.
> <regains composure />
> Well, this might be a job for a BPM. You could capture the Update
method and
> log who did what and search for ROWMOD="D" and log that to a file
or even
> send an email. It might be a little more work but you could capture
the
> CheckIn method and you could dump the PartMtl and EcoMtl records to
a file
> as well as the username.
> Mark W.
My engineering folks report to me today that they've seen some
instances of parts "disappearing" off of PartMtl/BOMs for assemblies.
This *could* be pilot error based on what I've heard, as the user
reporting the issue says he didn't verify the part after checkin, and
maybe there was some problem during the Engineering Workbench revision
checkin/approval process. That would be a different issue than things
that were checked in and stable suddenly getting changed.
We don't see any evidence of changes to the Parts in the ChangeLog.
Have folks seen anything similar? This is troubling (and a little
frustrating given that apparently this has been a Known Problem for a
month now!)
What version are you on?
Some apps on older versions didn't auto save after apparent record data editing or new entry (as perceived by the user). The user is just seeing the form populated with temp data that hadn't yet been written to the db.
You would have to press save.
Watch the user who reported it repeat their process (more than once). At some point, they will break into an entry/editing pattern different than how they started ("the right way" knowing you are looking over their shoulder). It is perfectly natural for people to do this (always looking for an easier way).
Once you ID the entry/editing sequence that is NOT resulting in a true save, test the theory by having them repeat it exactly, interrupt them and hit refresh. If you've found that right spot, their changes will revert (proving the changes were ever actually saved).
(Sloppy programming on Vantage's part but true - and not uncommon in object oriented interfaces as users always find ways to do things not anticipated by programmers.)
Once you know the spot, enable full tracing and have them repeat up to that same point. Stop and read the trace log to see what the last event was that you can leverage to force on save via an after_event subroutine with a simple otrans.update() statement as its guts.
Easy to overcome via a customization but annoying to track down - and even more annoying still that you have to do Epicor's software QC for them.
Rob
--- On Thu, 10/16/08, Brian W. Spolarich <bspolarich@...> wrote:
Subject: [Vantage] Disappearing PartMtl/BOM Entries
Date: Thursday, October 16, 2008, 5:46 PM
month now!)
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
We're running 8.03.405 SQL.
Internally we have a similar suspicion, that this is indeed "pilot
error", or at least an unexpected result based on some UI behavior. I'm
going to first suggest that he verify every BOM/PartRev after he commits
it to the system via method tracker to make sure he got what he
expected.
Just wanted to poll this group to see if there's some Known Issue that
we need to be aware of. The notion that Vantage would actually somehow
magically be deleting committed data is a little shocking and dubious,
but it doesn't surprise me if the transaction didn't get saved in the
way the user suspected (the Engineering Workbench is a reasonably
complicated UI and Epicor's QA definitely isn't perfect).
Thanks!
-brian
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Robert Brown
Sent: Thursday, October 16, 2008 11:55 PM
Subject: Re: [Vantage] Disappearing PartMtl/BOM Entries
db.
for an easier way).
them.
Rob
<bspolarich@...
month now!)
Do You Yahoo!?
Just an FYI... We had similar complaints about materials dropping off
looking in the change log to determine how a material got deleted. I
Craig
--- In vantage@yahoogroups.com, "Brian W. Spolarich "
behavior. I'm
commits
> expected.
that
somehow
dubious,
the
> Thanks!
> -brian
Photonix /
> Picometrix
Behalf
> Of Robert Brown
data
seeing
the
> db.
once). At
than
looking
> for an easier way).
true
them
not
to
event
subroutine
and
for
> them.
> Rob
> <bspolarich@...
> From: Brian W. Spolarich <bspolarich@...
assemblies.
and
revision
things
a
> month now!)
> Do You Yahoo!?
Wow.
Well, this might be a job for a BPM. You could capture the Update method and
log who did what and search for ROWMOD="D" and log that to a file or even
send an email. It might be a little more work but you could capture the
CheckIn method and you could dump the PartMtl and EcoMtl records to a file
Mark W.
