{Disarmed} Customer Terms
Jeff,
I have to say, I am glad that it does not change the open orders/quotes when
we change the customer's file. We have different payment terms depending on
what they purchase. If a customer would purchase a system from us we
normally do deposit with order/Net 30 days. If they are purchasing a part
from us the payment terms would be Net 15. For my standing point - it
works well for us.
What I wish it could handle is progress payments. 30% with Order / 20% 50%
Completion / 50% Net 30. That is more of problem for us on payment terms.
Sorry, could not be any help on this one.
Thank you,
Dina Hieber
Vamco International, Inc.
555 Epsilon Drive, Pittsburgh, PA 15238
Tel: (412) 963-7100
Fax: (412) 963-9511
email: dhieber@...
Website; www.vamcointernational.com
This e-mail message and any files transmitted with it are confidential and
are intended for the sole use of the intended recipient(s). Any unauthorized
use or disclosure is prohibited. Any opinions expressed in the email are
those of the individual and not necessarily the company. If you are not the
intended recipient, please contact the sender by reply email and destroy all
copies of the original message.
_____
Jeff Stockard
Sent: Tuesday, January 06, 2009 11:05 AM
Subject: {Disarmed} [Vantage] Customer Terms
Does anyone else have AR people that do not like having to go into every
open Sales Order and every open Quote to change Customer Payment Terms?
When a Customer's payment Terms change, Vantage does not change the payment
Terms on open Sales Orders or Quotes. The only way to change them is
manually. Are we the only company that has this problem?
Thank you
Jeff
after install 803 sql i launched the admin tools but information shows
that "There is no server for database d:\epicor\mfgsys803\db\mfgsyssh
(1423)"
and i can't start the database in Progress explore tools
what's wrong?
any advise ?
many thanks
What kind of errors are you getting when you try to start it? What do the logs
say?
32 bit? 64 bit?
Check your ODBC Connections, I prefer an SQL Server over the SQL Native Client
since it has less problems usually.
Check the Path of the Admin Icon since the install doesn't always create the
correct paths in the icon target line.
Check to make sure your SQL DB is connected and running
Check your paths in OpenEdge to make sure they are right.
mintokmint
Sent: Friday, January 02, 2009 8:48 AM
Subject: [Vantage] why i can't use 803 sql
(1423)"
what's wrong?
any advise ?
many thanks
D:\Epicor\OE100B\bin\prowin32.exe -pf d:\epicor\mfgsys803
\server\config\mfgtrain.pf -ininame d:\epicor\mfgsys803
\server\config\mfgsys.ini -p DataAdminMenu.w
my server is 32 bit
and i have checked ODBC it is right
and i can't start the db in progress explorer
can you help
many thanks
do the logs
> say?
> 32 bit? 64 bit?
Native Client
create the
Behalf Of
> mintokmint
shows
\db\mfgsyssh
> (1423)"
> what's wrong?
> any advise ?
> many thanks
must have
Builder and
I think I see the problem but not sure...
What version of 8.03 are you installing? 8.03.30x or 8.03.40x?
If it is a .400 level then I am guessing you are not opening up the right
version of OpenEdge or you have the wrong version of OpenEdge running on the
server.
Looking at the target line that is looking for OpenEdge version 10.0B not 10.1
which is what version .400+ uses.
Did you have a version of 8.03.30x on there and now are upgrading this server to
8.03.40x? If you have both versions, you need to make sure you set the OpenEdge
Admin Tool to "disabled" for version 10.0B in the Windows Services.
If so you will need to wipe out the schema holders that are already in place in
the d:\epicor\mfgsys803\db folder and replace it with a backup from
d:\epicor\mfgsys803\db\newdb since those schema holders are for OE 10.0B not
10.1B. Version 10.1 cannot start a version 10.0 DB and vice versa.
If this was an upgrade, you should have made a complete backup of those folders
and then wiped them prior to doing the backup in case you did run into a
problem. It is best to do an clean install into a blank folder when installing a
version which is not just a service pack upgrade.
Or, if you did all that, you are possibly just using the wrong icon to log into
the database admin tools.
mintokmint
Sent: Sunday, January 04, 2009 9:27 AM
Subject: [Vantage] Re: why i can't use 803 sql
my server is 32 bit
can you help
many thanks
do the logs
> say?
> 32 bit? 64 bit?
Native Client
create the
Behalf Of
> mintokmint
shows
\db\mfgsyssh
> (1423)"
> what's wrong?
> any advise ?
> many thanks
must have
Builder and
Thank you for your reply
You are right my DB is 10.0B and my Vantage is 803.400
but i have the same error when i installed 10.1B
i have download installation documment for 803 SQL.It is Said that
install 10.0B is OK.
could you tell me the right target line for this icon?
I install ON D:\Epicor\
Many thanks Again.
right
running on the
> server.
10.0B not 10.1
this server to
the OpenEdge
in place in
10.0B not
those folders
into a
installing a
to log into
Behalf Of
> mintokmint
> my server is 32 bit
> can you help
> many thanks
What
> do the logs
> > say?
> > 32 bit? 64 bit?
> Native Client
> create the
> Behalf Of
> > mintokmint
> shows
> \db\mfgsyssh
> > (1423)"
> > what's wrong?
> > any advise ?
> > many thanks
> must have
access. )
> Builder and
must have
Builder and
You cannot use OpenEdge 10.0B with Vantage 8.03.40x, it 100% will not work
since the vantage program is compiled using OpenEdge 10.1B.
If this is only a test server, then I would reccomend completely blowing
away your installation of all versions of OpenEdge and Vantage, then doing a
re-install using 10.1B.
If for some reason this is a live environment then you should get someone on
the phone and hire them to do the correct installation for you.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, January 05, 2009 9:03 AM
> Many thanks Again.
> right
> running on the
>> server.
> 10.0B not 10.1
> this server to
> the OpenEdge
> in place in
> 10.0B not
> those folders
> into a
> installing a
> to log into
> Behalf Of
>> mintokmint
>> my server is 32 bit
>> can you help
>> many thanks
> What
>> do the logs
>> > say?
>> > 32 bit? 64 bit?
>> Native Client
>> create the
>> Behalf Of
>> > mintokmint
>> shows
>> \db\mfgsyssh
>> > (1423)"
>> > what's wrong?
>> > any advise ?
>> > many thanks
>> must have
> access. )
>> Builder and
> must have
> Builder and
> have already linked your email address to a yahoo id to enable access. )
It is only a test.
and do you have any document about how to update Vantage 800
(OpenEdge) to 803.400(SQL)
Many thanks
not work
blowing
then doing a
someone on
> From: "mintokmint" <mintokmint@...>
> > Many thanks Again.
the
> > right
> > running on the
> >> server.
> > 10.0B not 10.1
> > this server to
set
> > the OpenEdge
Services.
already
> > in place in
from
OE
> > 10.0B not
versa.
> > those folders
> > into a
when
> > installing a
icon
> > to log into
> > Behalf Of
> >> mintokmint
> >> my server is 32 bit
> >> can you help
> >> many thanks
> > What
> >> do the logs
> >> > say?
> >> > 32 bit? 64 bit?
SQL
> >> Native Client
always
> >> create the
On
> >> Behalf Of
> >> > mintokmint
information
> >> shows
> >> \db\mfgsyssh
> >> > (1423)"
> >> > what's wrong?
> >> > any advise ?
> >> > many thanks
You
> >> must have
> > access. )
> >> Builder and
goto:
> > must have
access. )
> > Builder and
must
access. )
Builder and
Wait....
Are you currently on Vantage 8.00 with a progress openedge database and are
trying to upgrade to Vantage 8.03.40x with a SQL Database?
If so, then I wouldn't reccomend trying to do this yourself.
If you are just going from 8.00 to 8.03.40x but are staying with the same
database format then I would follow these steps(and if I miss any please
remind me)
1- Make a backup of your SQL DB
2- Shut down vantage and open edge 10.0B - Set the AdminService for OpenEdge
10.0B to manually start, or disabled in Windows Services, change the name of
any icons for the Progress Explorer Tool(PET) so they say 10.0B on them.
3- Make a full file copy of your entire "Epicor" folder
4- Inside the Epicor folder, delete the "MfgSys803" "Pilot803" "Test803" and
"Train803" folder.
5- Install OpenEdge 10.1B, then turn it off
6- Install Vantage 8.03.400
7- Service Pack Vantage
8- Start OpenEdge 10.1B
9- Open the PET, shut down all appservers and only leave the DB running
10- Run the Schema Update tool
11- Run Conversions
12- Restart the Appservers
those are the basics to get you updated.
There should be a document on EpicWeb that explains all this and walks you
through it as well, i'm just not sure exactly where it is.
Sent: Tuesday, January 06, 2009 8:51 AM
> It is only a test.
> Many thanks
> not work
> blowing
> then doing a
> someone on
>> > Many thanks Again.
> the
>> > right
>> > running on the
>> >> server.
>> > 10.0B not 10.1
>> > this server to
> set
>> > the OpenEdge
> Services.
> already
>> > in place in
> from
> OE
>> > 10.0B not
> versa.
>> > those folders
>> > into a
> when
>> > installing a
> icon
>> > to log into
>> > Behalf Of
>> >> mintokmint
>> >> my server is 32 bit
>> >> can you help
>> >> many thanks
>> > What
>> >> do the logs
>> >> > say?
>> >> > 32 bit? 64 bit?
> SQL
>> >> Native Client
> always
>> >> create the
> On
>> >> Behalf Of
>> >> > mintokmint
> information
>> >> shows
>> >> \db\mfgsyssh
>> >> > (1423)"
>> >> > what's wrong?
>> >> > any advise ?
>> >> > many thanks
> You
>> >> must have
>> > access. )
>> >> Builder and
> goto:
>> > must have
> access. )
>> > Builder and
> must
> access. )
> Builder and
Thank you
Jeff
