{Disarmed} RE: {Disarmed} Won't display data with Crys
Go to System Management > Utilities > Menu Maintenance. On the left side of the menu maintenance screen, you will see your existing menu tree. Navigate through the tree until you come to the folder where you want your report to go. Then select New Menu. In the bottom half of the menu detail, choose BAQ Report for the program type, and select the report you want attached to this menu item. The rest of the fields are pretty straightforward and the help on this screen should be able to give you the guidance you may need. After you save your new menu item, you have to exit Vantage/Vista and reopen it for the menu item to actually show up. HTH
Thom Rose
Controller
Electric Mirror, LLC
T 425 776-4946 ext. 1024
A 11831 Beverly Park Road, Building D, Everett, WA 98204 USA
www.electricmirror.com<http://www.electricmirror.com/>
Note: The information contained in this e-mail, including any attachments, is legally privileged and confidential. If you are not the intended recipient you are hereby notified that any reading, use or dissemination of this message is strictly prohibited. If you have received this message in error, please immediately notify us by telephone at 425-776-4946 and delete this message from your system. Even though this e-mail and any attachments are believed to be free of any virus or other defect that might affect any computer system into which it is received and opened, it is the responsibility of the recipient to ensure that it is virus free, and no responsibility is accepted by Electric Mirror LLC for any loss or damage arising in any way from its use. www.electricmirror.com<http://www.electricmirror.com>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Casey
Sent: Tuesday, May 13, 2008 7:13 AM
Subject: {Disarmed} RE: {Disarmed} [Vantage] Won't display data with Crystal
How do i attach this report to a menu item?
Thomas Rose <t.rose@...<mailto:t.rose%40electricmirror.com>> wrote: I am almost brand new to the system too. We are still pre-implementation from our legacy systems.
I had the same problem you have. I don't know why it happens, but I did come up with a workaround. Chances are, when you created the report, there is a copy of it in your custom reports folder (probably at \\Your Server Name\Epicor\mfgsys803\reports\customreports). If it is not there, but is on your local drive, copy it to your custom reports folder. Next, attach it to a menu item, either as the sole item on that menu item, or as a report style on another menu item (The details of how to do that is another subject, but let me know if you need guidance there). Now, run the report from your menu item. You will be able to see exactly how it looks with all the data in place. I do this to refine my reports. I have the report open in Crystal, I make my changes and save it. Then, without closing the report or Crystal, I run the report in Vantage/Vista and I see my changes. I just keep switching back and forth until I get the report I am happy with.
Someone else may have a better way to do this, but it works for me.
Thom Rose
Controller
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of skc143psu
Sent: Monday, May 12, 2008 1:43 PM
Subject: {Disarmed} [Vantage] Won't display data with Crystal
Hello,
I'm literally brand new to the Vantage system (8.03.305). I have
learned how to create BAQs for reports, but when I go into the BAQ
report designer, and go to actions -> design crystal report, crystal
will launch, but no data is displayed. Tried to get someone from Epicor
to help me, but no one has returned my email. I'm kinda embarrassed,
because I know this is pretty basic, but, like i said, I'm totally new
to this, and there was no one who designed reports before me, so I have
no reference. I think i may have something configured wrong. Any
thoughts? Thanks in advance.
Hello,
Thom Rose
Controller
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of skc143psu
Hello,
Did you "build" some sample data first? That is also on the action menu and I
think it needs the dataset to populate the database fields tree.
Mark W.
Yes, I forgot to mention that. After creating the BAQ, I open the report designer, create the option fields and filters, then test the report form through the actions menu, then generate sample data. It confirms that the sample data was created.
Mark Wonsil <mark_wonsil@...> wrote: > I'm literally brand new to the Vantage system (8.03.305). I have
Mark W.
Have you edited the report using Crystal? The report created by the BAQ
report program is basically a blank report, i.e. it only has a page
header.
Of Steven Casey
Sent: Tuesday, May 13, 2008 8:39 AM
Subject: RE: [Vantage] Won't display data with Crystal
Mark Wonsil <mark_wonsil@... <mailto:mark_wonsil%40yahoo.com> >
have
Epicor
have
and I
Mark W.
Charles Carden
Manager, MIS
Manitex, Inc.
Phone: 512-942-3086
Fax: 512-942-3089
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or
proprietary information, and may be used only by the person or entity to
which it is addressed. If the reader of this e-mail is not the intended
recipient or his or her authorized agent, the reader is hereby notified
that any dissemination, distribution or copying of this e-mail is
prohibited. If you have received this e-mail in error, please notify the
sender by replying to this message and delete this e-mail immediately.
Thomas Rose <t.rose@...> wrote: I am almost brand new to the system too. We are still pre-implementation from our legacy systems.
Thom Rose
Controller
Hello,
