Display Time
Jasper,
I ran into this also and here's what I used:
NumberVar MinNum:= If Len(ToText({LaborHed.LunchOutTime})) = 4 Then
ToNumber (Mid(ToText
({LaborHed.LunchOutTime}),2,3)) Else
({LaborHed.LunchOutTime}),3,3));
StringVar Hr:= If Len(ToText({LaborHed.LunchOutTime})) = 4 Then
"0" + Mid(ToText({LaborHed.LunchOutTime}),1,1) Else
Mid(ToText({LaborHed.LunchOutTime}),1,2);
StringVar Min:= If MinNum = .00 Then "00" Else Mid(Totext(MinNum *
60),1,2);
If {LaborHed.LunchOutTime} = 0.00 Then "00:00"
Else
Hr + ":" + Min
I hope this helps.
Aceplayr
--- In vantage@yahoogroups.com, "Jasper Recto" <jrecto@...> wrote:
> Does anybody know how I can convert the Actual Clock In time that
is in hundredths to an actual readable time?
> Thanks,
> Jasper
Does anybody know how I can convert the Actual Clock In time that is in hundredths to an actual readable time?
Jasper
If you are using the LaborHed or LaborDtl tables, there is a field
called "DspClockInTime" that might be what you want.
-Sarah
Of Jasper Recto
Sent: Monday, July 31, 2006 9:54 AM
To: Vantage Groups (E-mail)
Subject: [Vantage] Display Time
Jasper
Yahoo! Groups Links
That field is for the adjusted time. I need the actual time which does not have a built in display field.
Jasper
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Monday, July 31, 2006 10:15 AM
Subject: RE: [Vantage] Display Time
-Sarah
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of Jasper Recto
Jasper
http://groups. <http://groups.yahoo.com/group/vantage/files/.> yahoo.com/group/vantage/files/.
http://groups. <http://groups.yahoo.com/group/vantage/messages> yahoo.com/group/vantage/messages
http://groups. <http://groups.yahoo.com/group/vantage/links> yahoo.com/group/vantage/links
Yahoo! Groups Links
Jasper,
I don't know if there is an easier way but I wrote a function to do the
conversion in Access. I wasn't sure how Vantage deals with Midnight
(0:00 or 24:00) so I wrote in the word. I did the same for noon just to
be consistent. Our shifts change at 6am, 2pm, and 10pm so it hasn't
come up yet.
If anyone knows about how midnight is displayed, please let me know so I
can adjust.
Function ConvertTime(DecTime) As String
Dim hour As Integer
Dim min As Variant
Dim ampm As String
If DecTime < 0 Or DecTime > 24 Then
ConvertTime = "Error"
GoTo Exit_ConvertTime
End If
If IsNull(DecTime) Then
ConvertTime = ""
End If
If DecTime = 0 Or DecTime = 24 Then
ConvertTime = "Midnight"
End If
If DecTime = 12 Then
ConvertTime = "Noon"
End If
hour = Int(DecTime)
If hour < 12 Then
ampm = "am"
Else
ampm = "pm"
End If
min = DecTime - hour
min = Round(min * 60)
If min < 10 Then min = "0" & min
If min = 0 Then min = "00"
If hour > 12 Then hour = hour - 12
ConvertTime = hour & ":" & min & ampm
Exit_ConvertTime:
'MsgBox ConvertTime
End Function
Of Jasper Recto
Jasper
The formula in crystal and ms query and access is the same "DisplayTime:
(([systime] / 3600) / 24) "
There must be a way to apply this to Vantage forms.
Of Jasper Recto
Jasper
Check the System Management/Configuration Maintenance/Company
Configuration/Module Configuration/Job Management Configuration. There is a
Time Format on the left hand side, the 2nd set of options; you have a choice
of Hours/Minutes or Hours/Hundredths.
Hope that helps!
Cindy House
GTech Precision
Corporate Controller
(w) 817-539-8014
(f) 817-539-8018
(c) 817-832-8933
Jasper Recto
Sent: Monday, July 31, 2006 8:54 AM
Jasper
