Is there any way to divide one line from a requisition into several lines in different purchase orders? There are times, known after the req was made, where we may need to source the single req line from multiple vendors.
For instance, we would want to go from this:
To this:
Are you using Requisition -> PO Suggestion -> PO process?
I believe they’re using PO Suggestions > Generate POs
@hmwillett, As of now this functionality is not there in Epicor. The only possible way is to have release in Requisition.
The other alternative is to go with RFQ way.
