DMR - Auto Reject
If you purchase Service Connect, be aware that there is a VERY high learning curve to this software. XML experience is very helpful. The documentation and training falls far short from sufficient for this product. There are so many things that can go wrong. Documentation for reading the traces that are necessary to identify the methods to use is non-existent. There is no documentation available for error codes. On multiple occasions I was told by support that they don't support mappings which is a key part of Service Connect.
Â
So when you purchase this, plan on spending a LOT of labor dollars in getting it to work or a lot of consulting dollars so that someone else can get it to work.
Â
Trying to learn the hard way,
Â
Lorraine Aiello
Senior Programmer Analyst
Gloucester Engineering Co., Inc.
(plastics machinery manufacturing firm)
Gloucester, MA
--- On Wed, 7/22/09, Butler, Bruce <bbutler@...> wrote:
Subject: RE: [Vantage] DMR - Auto Reject
Date: Wednesday, July 22, 2009, 12:32 PM
Â
We maybe purchasing Service Connect as part of another project. I will
keep this on the backburner until then. For now, thanks for the heads
up.
Bruce
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Rob Bucek
Sent: Tuesday, July 21, 2009 2:20 PM
To: vantage@yahoogroups .com
Were having the same quandary here Bruce, however failed at inspection
could mean one of two possibilities afterwards, rework or scrap? A BPM
however wont be able to create the new record sets you'll need to
process or disposition through the DMR area. I identified a service
connect workflow called from a BPM as the best solution to automate
that. The BPM was the easy part as it works with a simple customization
that the inspector uses to auto process the DMR (canned choices). I
haven't gotten anywhere but a rough start with the work flow due to
priority changes... But in short, a BPM isn't going to do it for you in
DMR.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg com/>
(Click the logo to view our site) <http://www.dsmfg com/>
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Butler, Bruce
Sent: Tuesday, July 21, 2009 11:16 AM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Subject: [Vantage] DMR - Auto Reject
We are not using the Quality Module to the extent it was designed. Once
our Quality manager determines a material as failed through the
inspection, that is the end of the trail. To answer the DMR is simply
redundant for us. I am seeking some direction for writing a BPM to
auto-fail DMRs.
Bruce Butler
Information Systems Manager
Marvel Manufacturing Company, Inc. <http://www.sawing com/>
auto-fail DMRs.
Bruce Butler
Marvel Manufacturing Company, Inc. <http://www.sawing.com/>
DMR.
Rob Bucek
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of Butler, Bruce
auto-fail DMRs.
Bruce Butler
up.
Bruce
Of Rob Bucek
DMR.
Rob Bucek
FAX: (715)284-4084
Behalf
Of Butler, Bruce
auto-fail DMRs.
Bruce Butler
