DMT and Part.Inactive
Brian,
Next time you're up this way, I'll buy you dinner.
Yeah, I had a BPM on Part.Inactive. Sigh.
Thanks!
Ernie
--- In vantage@yahoogroups.com, "Brian Roberts" <broberts@...> wrote:
> We just used DMT to mark a bunch of parts inactive, zero problems.
> Version 9.05.607B.
> Template had only 3 columns:
> Company
> PartNum
> InActive
> With a 1 in the InActive column.
> That "InfoPromptHandler" error message is odd... do you have a BPM on
> Part.Update?
> Thanks,
> Brian.
> Of gracefulthreads
> Sent: Thursday, September 13, 2012 10:45 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] DMT and Part.Inactive
> I have about 700 part numbers I need to set as "inactive". All have no
> stock and no demand (at least as far as I can tell).
> When I try to use the DMT to set the "Inactive" field to "TRUE", I get
> an error:
> Context handler with "InfoPromptHandler" name is not found.
> This error is generated for EACH part number.
> In looking at the Part Maintenance Application Help, we find this
> nugget: "Also note that this check box is only available when you launch
> Part Maintenance from the Main Menu. If you are updating a part record
> from a search browser activated from a program like Quote Entry, this
> check box is disabled."
> Would that stipulation also apply to the DMT option, and am I therefore
> stuck with opening 700-odd part records and manually checking the boxes?
> Get the rubber room ready...
> Ernie Lowell
> Diba Industries
I have about 700 part numbers I need to set as "inactive". All have no stock and no demand (at least as far as I can tell).
When I try to use the DMT to set the "Inactive" field to "TRUE", I get an error:
In looking at the Part Maintenance Application Help, we find this nugget: "Also note that this check box is only available when you launch Part Maintenance from the Main Menu. If you are updating a part record from a search browser activated from a program like Quote Entry, this check box is disabled."
Would that stipulation also apply to the DMT option, and am I therefore stuck with opening 700-odd part records and manually checking the boxes?
Ernie Lowell
Diba Industries
Version 9.05.607B.
Company
PartNum
InActive
Part.Update?
Brian.
Of gracefulthreads
an error:
Ernie Lowell
Diba Industries
I used DMT to set 850 parts to "inactive".
I can't help you with the specific error you are seeing but I can say it can be done with DMT, at least with the version we are using (9.05-604A).
Did you use a template generated by DMT?
Mike Barlett
Elsner Engineering Works
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of gracefulthreads
Ernie Lowell
Diba Industries
