DMT BOM Import Tables Access to plant denied
The Plant would help too!!!
Sent from my iPhone
On Mar 31, 2016, at 3:16 PM, clive.gillett@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1779409053ygrp-text">
  <p>Stephen, that was it. I forgot to populate the plant field.</p><div><br></div><div>Thank you</div><p></p>
</div>
I am trying to run a DMT update on an existing part's BOM. When I do I get I get the error
Method (SetPlant) Table Access to plant denied.
Does anyone know what might cause this issue?
Thank you in advance.
#ygrps-yiv-57201256 P.ygrps-yiv-57201256b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-57201256 LI.ygrps-yiv-57201256b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-57201256 DIV.ygrps-yiv-57201256b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-57201256 TABLE.ygrps-yiv-57201256b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-57201256 DIV.ygrps-yiv-57201256Section1 { }
Clive
Does your user have access to the plant / site referenced and is it correctly cased
Sent from my iPhone
On 31 Mar 2016, at 19:22, clive.gillett@... [vantage] <vantage@yahoogroups.com> wrote:
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
Thank you
Go out of DMT and log back into Epicor.  Select the plant were you want to DMT the parts to.  Log back into DMT and it should work now.  Epicor remembers the last plant the account you was logged into.
Sent from my iPhone
On Mar 31, 2016, at 2:22 PM, clive.gillett@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-2018498574ygrp-text">
  <p>I am trying to run a DMT update on an existing part&#39;s BOM. When I do I get I get the error</p><div>Method (SetPlant) Table Access to plant denied.</div><div><br></div><div>Does anyone know what might cause this issue?</div><div><br></div><div>Thank you in advance.<br><p><span><br class="ygrps-yiv-2018498574yui-cursor"></span></p></div><p></p>
</div>
