DMT -ConfigValue command line parameter
Does someone know whether this parameter is looking for a fulling path name of a file located in the \Client\Config directory? or something else?
I can’t find an answer anywhere….
Thank you.
Christophe
It is looking for the same value you see in the environment drop-down when using the DMT user interface.
Thanks Dan.
Though I use the DMT daily - and the command line too -, I don’t know where to find the environment drop-down that you mention. From the search box, nothing returns when I type “env”. Could you do a screen shot or something else to point me in the right direction?
Thank you.
Christophe
Never mind Dan…
I think you meant the drop down at the login screen of the DMT.
Got it!
Thank you.
