DMT Issue
Now that DMT updates automatically when you upgrade Epicor version, and updates automatically when you upgrade. What do you do when you run into a version error?
Quantity Adjustment uses the current date for TransDate even when you backdate it, something that worked before we upgraded.
I think first steps would be to reach out to support.
What version are you using?
I just tested and was able to backdate fine on most recent version. Perhaps this is an older bug that they fixed in the latest?
First backdated to 9/1/2024… then ran it again backdating a full year at 9/1/2023… both went through.
Pilot Environment and DMT both @ 11.3.100.10
In the end, I had to move the TransDate column all the way to right on my DMT spreadsheet and then it worked. Strange because for years before the column order was what I used this time. But I suppose something changed along the way.
Well, at least its working! Nice job figuring it out.
