I am trying to remove Materials using DMT. Today, after selecting Delete and then Process, it just sits there and does nothing. Hit cancel and it does nothing. So I have to use the task manager to get it to stop. Ideas on why this is doing that? I really do NOT want to remove all this one at a time.
Try a DMT file with just a couple of rows, or even just 1 row. Maybe it takes a lot longer per row than you think.
And are you removing Mtl from Jobs or BOMs?
BOMâs
Just sits on zero percent. I have only two lines and still just sitting. Crazy!
I assume an ECO is required to change the BOM, via DMT. Did you create an ECO just for this DMT process?
And there are quite a few steps (and behind the scenes processing) required to remove material from a BOM. So I would expect that to go slowâŚ
Yes, I use the same one all the time. All the others go through just fine. IDK.
So just one particular BOM?
I was just doing a test and got a âhexadecimal value 0x1E, is an invalid characterâ error.
I copied the XLSX file contents to a Text Editor, then back to the XLS file. And then it worked.
I havenât done an BOM with DMT for a long time, but no issues before. For whatever reason, this is not going through. Guess by hand I go. Nothing in the text editor stood out as an potential issue.
I was able to remove a Mtl from a BOM with just the following fields
I pulled that data from a query of PartMtl (which doesnât have the Plant field)
I have the same fields.
Company, PartNum, RevNum, MtlSeq, MtlPartNum, Plant, ECO
Are you sure youâr only trying to change approved BOMâs? It might be getting stuck on trying to checkout a BOM thatâs not approved, or possibly already checked out to another ECO.
Field sequence can be important in DMT - behind the scenes it is running the BO calls in the same order that the UI screen would.
Suggest changing your column order to match Calvinâs example that works, see if it behaves differently.
Tried that to no avail. I did notice that after 30 minutes it was on 2%. So, its doing something but its VERY slow.
@markdamen @ckrusen I decided to let the DMT run and got this error after a while: Error: Exception of type âSystem.OutOfMemoryExceptionâ was thrown.
Enable tracing to see what BO is failing with what data.
When I was getting the illegal char error, the trace log would abruptly end likeâŚ
Scrolling back showed it was in the
<businessObject>Erp.Proxy.BO.EngWorkBenchImpl</businessObject>
<methodName>GetRows</methodName>
section
Use a brand new ECO Group and see if any differenceâŚ
Did you download an update for the DMT tool? We have noticed that may of the updates break the BOM DMT. We have to revert back to using the prior version.
@bw2868bond I am trying a new one, and so far still slow.
@utaylor No, I have not updated it. But I went ahead and removed it from the system files, and then took the back up one and put it in. Still slow.
@ckrusen I have the tracing on, so far, no hits to the system. However, it will take almsot an hour before it does much of anything.
I avoid updating DMT, like I avoid the âSync Datasetâ button in Report Style maint. ![]()
Apparently all I needed was to use the newer version of DMT. That worked with no issues.
