DMT - Lowercase companies - 'Company is a key column'
Has anyone run into an issue where your Company ID contains lowercase letters, and DMT converts it to uppercase on import? The load then fails because DMT treats it as an attempt to change the Company ID.
There’s an EpicCare case on this, but the only resolution offered is to upgrade, which isn’t an option right now.
Has anyone found a workaround?
One of our Company IDs has a lowercase letter and it hasn’t caused any problems with DMT (yet).
Interesting! Can I ask what version you are on?
2026.100.14, but we’ve used DMT on whatever’s been the current version since 2020 with no issues.
That said, we haven’t used DMT in a couple of months, and we just upgraded from 2025.2 last weekend. It’s entirely possible that it’s a new bug.
Yes I have ran into this many times, support has a data fix to fix the case so then the DMT will work again.
Thank you! Working on getting the fix with Epicor Support - however, they’ve completed ignored the request and told us the solution is to upgrade. lol.
