Good luck with your launch. Are you looking for the order of which DMTs to process?
For the DMT’s you’ll want to do them in the following order:
Part
Part Plant
Part Revision
Bill Of Operations
Bill Of Materials
That is of course assuming you only have one level in your methods. If you start introducing subassemblies then things get screwy.
I’d highly recommend doing a quick search on powershell with DMT, the combination is exceptionally powerful.
