Is there a trick to getting a DMT upload file to correctly recognize “OrderRel#FirmRelease”? I cannot get the field to be marked as “false”. I’ve tried “0”, “NO”, “FALSE”. I’ve tried formatting the column to different types. Nothing seems to work
Only other thing I can think of - check the column sequence on your DMT file. Saw it mentioned in the below thread…sometimes it can make a difference in what does/doesn’t update right.
okay, on my initial import file I had both “OrderRel#OrderRelNum” and “OrderRel#FirmRelease”. Removing just “OrderRel#FirmRelease” still imported the releases as firm. Removing both columns and not having any “OrderRel” columns at all still imports the releases as firm. I’m guessing it’s either our version of DMT, Epicor, or a specific setting in our company/site config or specific modules we are or aren’t licensed for.
