DMT Script Error Message
In the DMT Labs and Template zip you get from epicweb there are.
Basically this command in a .cmd or .bat file
Start /w DMT.exe -Import="Product Group" -Source "C:\Imports\ProdGrps.xls" -Add user manager -pass manager -server localhost -port 9011 -HideGUI
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of P
Sent: Wednesday, August 29, 2012 9:30 AM
Subject: [Vantage] Re: DMT Script Error Message
Is there documentation for auto runnign DMT?
Thanks, Pam
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "james.terranova@...<mailto:james.terranova@...>" <jimt@...<mailto:jimt@...>> wrote:
> We're successfully running some DMT "AutoTestScripts" that we've copied from the DMT template scripting directory. Everything runs fine except for each time the script attempts to opens DMT, we receive an "Installation Error" message box that states "Error ensure DMT is running from you Epicor Client directory". You click OK to accept the error, DMT loads, runs the file and all is well. We have the SET SERVER, SET PORT, SET DMTPath and SET TPath variables filled in and they all seem to be working correctly.
> Does anyone know what the correction is for this?
> Jim Terranova
> Accel Group Inc
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
Jim Terranova
Accel Group Inc
Thanks, Pam
> Jim Terranova
> Accel Group Inc
