DMT sequence import
Can anyone tell me where can I get masterfile data DMT import sequence list? Thank you in advance.
It’s “built-in” to DMT. There a couple of ways the DMT interface can be used, one of them (I forget the name) lists the imports, in order that you’d use them to make a new company. I think it has “Phase” in the description.
Edit
Use the Migration menu
If you launch DMT in Classic mode, select Migration from the menu on the right:
Then the main menubar will be like:
Dear Calvin Krusen,
Thanks for your prompt reply.
