DMT showing more records than BAQ
I have DMT’d the same UD Tables 3 times, and the DMT is telling me that there’s 2000+ records uploaded with 0 errors, but when I run a BAQ, it says that there’s only 400+ records…what can cause this?
If any of the LATER records have the same Key1-2-3-4-5 values as a previous record, the previous record will be overwritten. Check all your keys and make sure each of the 2000+ records all have UNIQUE key values.
